Learn how to create ConvertKit subscribers from Wix using Pabbly Connect. Follow this detailed tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for Wix-ConvertKit Integration
To begin the integration process, access Pabbly Connect by typing the URL Pabbly.com/connect in your browser. This is the platform that will facilitate the connection between Wix and ConvertKit.
Once on the landing page, you will see options to sign up or sign in. As an existing user, click on the ‘Sign In’ button. You will then be directed to the applications page where you can access various Pabbly products. Click on ‘Access Now’ for Pabbly Connect to proceed.
After signing in to Pabbly Connect, you will be taken to the dashboard. Here, locate the ‘Create Workflow’ tab on the right side and click on it. A dialog box will prompt you to name your workflow.
For this integration, name your workflow ‘Create ConvertKit Subscriber from Wix’ and click on ‘Create’. This sets up the framework for your automation, where Wix will serve as the trigger application and ConvertKit as the action application.
3. Setting Up the Trigger Event from Wix
In this step, you will configure the trigger event in Pabbly Connect. Click on the Wix icon as your trigger application. Select the trigger event as ‘Configure Webhooks’. This step is crucial as it establishes the connection between Wix and Pabbly Connect.
Upon selecting the trigger, you will be provided with a webhook URL. Copy this URL as it will be used in your Wix developer settings. Follow the instructions provided in Pabbly Connect to set up this webhook in your Wix account.
  • Log into the Wix Developer Center.
  • Create a new app and name it accordingly.
  • Set permissions for managing contacts.
  • Add the webhook URL to the app settings.
Once you have completed these steps, return to Pabbly Connect and perform a test submission to ensure the webhook is functioning correctly. This will allow Pabbly Connect to capture the data from Wix.
4. Adding Subscribers to ConvertKit
After successfully setting up the webhook, the next step in Pabbly Connect is to add subscribers to ConvertKit. Select ConvertKit as your action application and choose the action event ‘Add Subscriber to a Form’. This will allow you to send the data captured from Wix directly to ConvertKit.
Connect your ConvertKit account by providing the necessary API key and secret. This information can be found in your ConvertKit account under the API settings. Once connected, you will be able to map the data fields from Wix to ConvertKit.
  • Map the first name and email address fields from Wix to ConvertKit.
  • Select the appropriate form where subscribers will be added.
  • Set any tags if necessary for segmentation.
After mapping the fields, click on ‘Save and Send Test Request’ to confirm that the integration is working properly. You should see the subscriber appear in your ConvertKit account.
5. Confirming Subscribers in ConvertKit
Once the subscriber is added to ConvertKit, they will initially appear as unconfirmed. To confirm the subscription, the user must check their email and click on the confirmation link. This step ensures that your subscribers are genuine and have opted in to receive communications.
Navigate to your ConvertKit account and check the ‘Unconfirmed Subscribers’ section to see if the new subscriber has appeared. After the user confirms their subscription, they will move to the ‘Confirmed Subscribers’ list. This process verifies that the integration via Pabbly Connect is successful and functioning as intended.
To test the integration further, create another contact in Wix and repeat the process. Each new contact should automatically be added to ConvertKit as a subscriber, confirming the reliability of your integration setup through Pabbly Connect.
Integrating Wix with ConvertKit using Pabbly Connect allows you to automate the process of adding subscribers seamlessly. By following the steps outlined in this tutorial, you can ensure that every new contact created in Wix is automatically added as a subscriber in ConvertKit, streamlining your email marketing efforts.
Utilizing Pabbly Connect for this integration not only saves time but also enhances your marketing efficiency. Start leveraging this powerful automation tool today to maximize your outreach and engagement.
