Learn how to integrate Typeform leads into Sendinblue using Pabbly Connect with this detailed tutorial. Automate your lead capturing process effortlessly! Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To integrate Typeform leads into Sendinblue, you first need to access Pabbly Connect. Start by typing ‘Pabbly.com’ in your browser and navigate to the products section to select Pabbly Connect.
As a first-time user, click on the ‘Sign Up for Free’ option to create your account. After signing up, you will receive 100 free tasks each month. If you already have an account, simply sign in and access Pabbly Connect from the dashboard.
Once logged into Pabbly Connect, create a new workflow by clicking on the plus sign. Name your workflow, for example, ‘Add Typeform Leads to Sendinblue’, and click on ‘Create’. This step sets the stage for the automation process.
In the newly created workflow, you will see a trigger window and an action window. Pabbly Connect operates on a trigger-action model. For this integration, the trigger will be a new entry in Typeform, which will initiate the action of adding a contact in Sendinblue.
- Click on the trigger window and select Typeform as the application.
- Choose ‘New Entry’ as the trigger event.
- Connect your Typeform account by clicking ‘Connect’ and then ‘Add New Connection’.
After connecting, select the form you want to use for capturing leads. Ensure that your Typeform is ready and published for customer submissions.
3. Setting Up Typeform Connection in Pabbly Connect
In this step, you will finalize the Typeform connection within Pabbly Connect. After selecting your Typeform, you need to test the connection by submitting a test entry.
Fill out the Typeform with test data, such as a name, email, and phone number. Once submitted, return to Pabbly Connect and click on ‘Save and Send Test Request’. This will allow Pabbly Connect to capture the lead details from Typeform.
- Enter details like first name, last name, email, and mobile number in the Typeform.
- After submission, check Pabbly Connect for captured responses.
Ensure that all details are correctly captured before moving to the next step, which involves integrating with Sendinblue.
4. Connecting to Sendinblue in Pabbly Connect
Now that you have successfully captured Typeform responses, it’s time to connect to Sendinblue through Pabbly Connect. In the action window, search for Sendinblue and select it as the application.
Select ‘Create or Update Contact’ as the action event. Click on ‘Connect’, then ‘Add New Connection’. You will need to provide your Sendinblue API key to establish this connection.
Log in to your Sendinblue account and navigate to the SMTP & API section. Generate a new API key and copy it into Pabbly Connect.
After successfully connecting, map the captured Typeform fields to the corresponding fields in Sendinblue, ensuring that the email and other details are accurately transferred.
5. Testing the Integration Between Typeform and Sendinblue
To ensure that the integration is functioning correctly, perform a test by submitting another entry in Typeform. After submission, check your Sendinblue account to see if the new contact has been added successfully.
Refresh your Sendinblue contacts list to verify that the details from Typeform have been accurately transferred into your email marketing platform. This confirms that Pabbly Connect is effectively automating the lead capture process.
Once you confirm the integration works, save your workflow in Pabbly Connect. This ensures that all future Typeform submissions will automatically create or update contacts in Sendinblue.
Integrating Typeform leads into Sendinblue using Pabbly Connect allows for seamless lead management. By following the steps outlined above, you can automate your lead capture process effectively. This integration not only saves time but also enhances your marketing efforts.
