Learn how to automate adding new Ticket Tailor customers to Sendinblue using Pabbly Connect with this step-by-step tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for Ticket Tailor and Sendinblue Integration
To begin, you need to access Pabbly Connect, which is the central platform for this integration. Start by signing up for a free account on the Pabbly Connect dashboard. Once you are logged in, click on ‘Create Workflow’ and name it something relevant, such as ‘Ticket Tailor to Sendinblue’.
After creating the workflow, you will see two windows: the trigger window and the action window. The trigger window is where you set the event that starts the automation, while the action window defines what happens next. This setup will allow you to automate the process of adding new Ticket Tailor customers to your Sendinblue account.
2. Configuring the Ticket Tailor Trigger in Pabbly Connect
In the trigger window of Pabbly Connect, select ‘Ticket Tailor’ as the app. From the trigger event dropdown, choose ‘New Ticket Order’. This event will trigger every time a customer purchases a ticket. Once selected, Pabbly Connect will provide you with a webhook URL that you will need to connect to your Ticket Tailor account.
- Go to your Ticket Tailor account and navigate to the settings.
- Select the API option and then click on Webhooks.
- Click on ‘Create New Webhook’ and paste the webhook URL from Pabbly Connect.
- Set the event to ‘Order Created’ and ensure the status is active.
After completing these steps, every time a new ticket is ordered, the customer details will be sent to Pabbly Connect. You should see a message indicating that Pabbly Connect is waiting for a webhook response, confirming the connection is set up correctly.
3. Testing the Ticket Tailor Integration with Pabbly Connect
To test the integration, you will need to create a test order in Ticket Tailor. Navigate to your event page and select the option to join the guest list or purchase a ticket. Enter the customer details, including name and email, and complete the order process.
Once the order is placed, return to Pabbly Connect. You should see the details of the new order appear in the webhook response. This response includes crucial information such as the customer’s name, email address, and ticket details. This confirms that the integration is functioning as intended, capturing customer data from Ticket Tailor.
4. Setting Up the Sendinblue Action in Pabbly Connect
Now that the trigger is working, it’s time to set up the action in Pabbly Connect. In the action window, search for and select ‘Sendinblue’. Choose the action event ‘Create Contact’. This will allow you to add the customer details captured from Ticket Tailor to your Sendinblue contacts.
- Connect your Sendinblue account by entering the API key, which you can find in your Sendinblue account settings under SMTP & API.
- Select the contact list where you want to add new contacts.
- Map the email and other customer details from the webhook response to the corresponding fields in Sendinblue.
After mapping the fields, click on ‘Send Test Request’. If everything is set up correctly, you should receive a positive response indicating that the new contact has been successfully created in your Sendinblue account.
5. Verifying the Success of the Integration
To verify the integration, go back to your Sendinblue account and check the contacts list you selected earlier. You should see the newly added contact with the same details you entered during the test order in Ticket Tailor. This confirms that the integration via Pabbly Connect is working seamlessly.
To further test, you can repeat the order process with different customer details. Each new order in Ticket Tailor should automatically add the customer to Sendinblue, demonstrating the efficiency of this automation. This setup not only saves time but also ensures that your customer data is consistently updated across platforms.
In this tutorial, we explored how to integrate Ticket Tailor with Sendinblue using Pabbly Connect. This integration automates the process of adding new customers, ensuring that your email marketing efforts can be more effective and timely. By following these steps, you can streamline your ticketing and email marketing processes effortlessly.
