Learn how to automate adding Thrivecart customers to Sendinblue contacts using Pabbly Connect in this detailed tutorial. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Access Pabbly Connect to Get Started
To automate the process of adding Thrivecart customers to Sendinblue, you first need to access Pabbly Connect. This platform allows you to create workflows that connect different applications seamlessly. Begin by logging into your Pabbly Connect account. If you don’t have an account yet, you can create one easily by following the link provided in the description.
Once logged in, you will be directed to the dashboard of Pabbly Connect. Here, you will create a new workflow that will automate the integration process between Thrivecart and Sendinblue. This setup requires no coding skills, making it accessible for everyone.
To set up the automation, click on the ‘Create Workflow’ button in your Pabbly Connect dashboard. You will be prompted to name your workflow; a suitable name could be ‘Add Thrivecart Customers to Sendinblue Automatically’. After naming it, click on the ‘Create’ button.
- Enter a name for your workflow.
- Select the trigger and action applications.
After creating the workflow, you will see options for setting up a trigger and an action. The trigger will be the event that starts the automation, while the action will be the response to that trigger. In this case, the trigger will be a product purchase in Thrivecart, and the action will be to add the customer to Sendinblue.
3. Set the Trigger for Thrivecart Purchases
The next step involves setting the trigger in Pabbly Connect. Click on the trigger application and select Thrivecart from the list. Then, choose the trigger event as ‘Product Purchase’. This means that the workflow will be activated every time a product is purchased in Thrivecart.
After selecting the trigger event, click on ‘Connect’ and then choose ‘Add New Connection’. You will need to enter your Thrivecart API key, which can be found in the settings of your Thrivecart account. This key is essential for Pabbly Connect to communicate with Thrivecart.
4. Make a Test Purchase to Capture Data
Once the trigger is set up, it’s time to test the workflow. You will need to make a test purchase on your Thrivecart sales page. This can be done by filling in the necessary customer details, such as name and email address, and completing the purchase process.
After making the test purchase, return to Pabbly Connect and check if the data has been captured successfully. The details of the customer who made the purchase should now appear in the response section of your workflow. This confirms that Pabbly Connect is receiving data from Thrivecart correctly.
5. Create Contact in Sendinblue
With the trigger successfully set, the next step is to add the action to create a contact in Sendinblue. Select Sendinblue as the action application and choose ‘Create Contact’ as the action event. Click on ‘Connect’ and select ‘Add New Connection’ to link your Sendinblue account to Pabbly Connect.
You will need to provide your Sendinblue API key for this connection. Once connected, select the list where you want to add the new contacts. Map the customer details from the Thrivecart purchase to the corresponding fields in Sendinblue. Finally, test the action to ensure that the contact is created successfully in your Sendinblue account.
In this tutorial, we demonstrated how to integrate Thrivecart with Sendinblue using Pabbly Connect. By following the steps outlined, you can automate the process of adding new customers to your email marketing list effortlessly. This integration not only saves time but also enhances your marketing efforts by ensuring that all customer data is captured accurately.
