Learn how to seamlessly integrate ThriveCart with Gurucan using Pabbly Connect. Follow our step-by-step guide to automate user enrollment effortlessly. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Access Pabbly Connect to Set Up Integration
To start integrating ThriveCart with Gurucan, you first need to access Pabbly Connect. This is the central platform that facilitates the automation process. Go to the Pabbly Connect dashboard by visiting Pabbly.com/connect and create a free account if you haven’t already.
Once logged in, you can begin setting up your automation workflow. Click on the ‘Create Workflow’ button. Name your workflow something relevant, such as ‘ThriveCart to Gurucan Integration’. This will help you identify it later on your dashboard.
2. Setting Up Trigger Event in Pabbly Connect
In this step, you will configure the trigger event for your workflow in Pabbly Connect. The trigger event will be based on a new sale occurring in ThriveCart. Start by selecting ThriveCart as your trigger application.
- Choose ‘ThriveCart’ from the app options.
- Select ‘Product Purchase’ as the trigger event.
- Connect your ThriveCart account by entering the API key found in your ThriveCart settings.
After connecting, you will need to specify the product you want to track. Select the relevant product from the dropdown list, ensuring it matches the course you are selling. Once configured, click ‘Save and Send Test Request’ to verify the connection.
3. Performing a Test Purchase to Validate Integration
To ensure that the trigger is working correctly, you need to perform a test purchase. This step is crucial as it allows Pabbly Connect to capture the data from the sale. Navigate to your ThriveCart checkout page and fill in the customer details.
Make a sample purchase using test card details. After completing the order, return to your Pabbly Connect workflow to check if the data has been received. You should see the details of the purchase, including the customer’s name and email address.
4. Creating a Student in Gurucan Using Pabbly Connect
With the purchase data received, the next step is to create a student in Gurucan. This is where Pabbly Connect plays a vital role. Select Gurucan as your action application and choose ‘Create Student’ as the action event.
- Connect to Gurucan by entering the API key and domain name.
- Map the customer data received from the ThriveCart purchase.
- Click ‘Save and Send Test Request’ to create the student in Gurucan.
After sending the test request, you should verify that the student has been successfully added to your Gurucan dashboard. Check the user section to confirm the new student appears with the correct details.
5. Enrolling the Student into a Course in Gurucan
The final step in this integration is to enroll the newly created student into a specific course in Gurucan. Again, this is done through Pabbly Connect. Add another action step in your workflow, selecting Gurucan and then ‘Enroll into Course’ as the action event.
Map the email of the student and select the course name from the dropdown. Since the payment has already been processed, you can skip sending a payment email. Click ‘Save and Send Test Request’ to complete the enrollment process. Once you receive a successful response, check the Gurucan dashboard to confirm the student is enrolled in the course.
By following these steps, you can effectively integrate ThriveCart with Gurucan using Pabbly Connect. This automation saves time and reduces manual effort by enrolling students automatically after a purchase. Start using this powerful integration today to streamline your course enrollment process.
