Learn how to create and update MailerLite subscribers on Tally Forms submission using Pabbly Connect. Step-by-step tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin integrating Tally Forms with MailerLite, you need to access Pabbly Connect. Start by visiting the Pabbly website and signing in to your account. If you are a new user, you can sign up for free and receive 100 tasks monthly.
Once logged in, navigate to the dashboard where you can find all your workflows. Select the Pabbly Connect application to initiate the integration process. This platform will serve as the bridge between Tally Forms and MailerLite, allowing for seamless data transfer upon form submission.
After accessing Pabbly Connect, create a new workflow by clicking on the ‘+ Create Workflow’ button. Name your workflow something descriptive, such as ‘Tally Forms to MailerLite Integration’. This will help you identify the workflow later.
- Select Tally as the trigger application.
- Click on ‘Connect’ to link your Tally account.
By completing these steps, you prepare Pabbly Connect to listen for new submissions from your Tally Forms. This is crucial for the automation process to function correctly.
3. Setting Up Tally Forms for Submission
Next, you need to set up your Tally Forms to send data to Pabbly Connect. Go to your Tally Forms account and select the form you want to integrate. Click on the ‘Integrations’ option within the form settings.
- Paste the webhook URL provided by Pabbly Connect.
- Save the changes to your form.
With this setup, every time a new form submission occurs, Tally will send the data to Pabbly Connect, which will then trigger the next steps in your workflow.
4. Configuring MailerLite to Receive Data
Now that Tally Forms are connected to Pabbly Connect, it’s time to set up MailerLite as the action application. In your workflow, select MailerLite and then choose the action event ‘Create/Update Subscriber’. This will allow you to add new subscribers or update existing ones based on the submissions.
Connect your MailerLite account by entering the API key. You can find this key in your MailerLite account settings under the API section. Once connected, map the fields from Tally Forms to MailerLite, ensuring that the email and other subscriber details are correctly aligned.
5. Testing the Integration
To ensure everything is functioning correctly, perform a test submission on your Tally Form. After submitting the form, check Pabbly Connect to see if the data was captured. You should see a response indicating that the data has been received.
Finally, log into your MailerLite account to confirm that the subscriber has been created or updated based on your test submission. This end-to-end testing verifies that your integration is working smoothly and that Pabbly Connect is effectively linking Tally Forms with MailerLite.
Integrating Tally Forms with MailerLite using Pabbly Connect allows for automated subscriber management, enhancing your marketing efforts. By following the steps outlined, you can ensure seamless updates and new subscriber creation with every form submission.
