Learn how to integrate Systema.io with MailerLite using Pabbly Connect. This detailed tutorial covers every step in the integration process, ensuring seamless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To integrate Systema.io with MailerLite, start by accessing Pabbly Connect. Navigate to the Pabbly website and select the option to sign in or sign up for a free account. New users can create an account quickly and receive 100 free tasks to explore the platform.
Once logged in, you will be directed to the dashboard. Here, locate the option to create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the integration between Systema.io and MailerLite, facilitated by Pabbly Connect.
2. Setting Up the Trigger with Systema.io
In this section, you will set up the trigger for your workflow using Systema.io. Select Systema.io as the trigger application and choose the trigger event as ‘Contact Subscribed to a Form’. This event is essential as it captures the form submissions from your Systema.io account.
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. Follow the instructions carefully to connect your Systema.io form to this webhook. You will need to set up automation rules in Systema.io to send data to this URL whenever a new form is submitted. This ensures that Pabbly Connect receives the necessary data for further processing.
- Select the appropriate funnel in Systema.io.
- Create a new rule to trigger the webhook upon form submission.
- Save the automation rule to ensure it is active.
Once you have set up the trigger, return to Pabbly Connect, which will now be waiting for a webhook response to confirm that the integration is working correctly.
3. Testing the Webhook Response
Now that the trigger is set up, it’s time to test the webhook response. Go to your Systema.io form and submit a test entry. Fill in the required fields with dummy data to simulate a real lead submission. This step is crucial as it allows Pabbly Connect to capture the data sent from Systema.io.
After submitting the form, return to Pabbly Connect to check if the webhook has received the data correctly. You should see the response populated with the details you just entered. This confirms that the integration is functioning as intended and that Pabbly Connect is effectively capturing the data.
4. Setting Up the Action with MailerLite
With the trigger successfully tested, the next step is to set up the action in MailerLite. Select MailerLite as the action application and choose the event ‘Add or Update Subscriber’. This event allows you to create a new subscriber in your MailerLite account using the data captured from Systema.io.
To connect MailerLite with Pabbly Connect, you will need to enter your MailerLite API key. This can be found in your MailerLite account under the integrations section. Once you enter the API key and establish the connection, you can proceed to map the fields from the webhook response to the corresponding fields in MailerLite.
- Select the appropriate group in MailerLite for new subscribers.
- Map the email and other fields from Systema.io to MailerLite.
- Save and send a test request to create the subscriber.
After mapping the fields, click on ‘Save and Send Test Request’ to create a new subscriber in MailerLite. You should see a confirmation of the new subscriber creation, indicating that Pabbly Connect has successfully integrated the two applications.
5. Confirming the Subscription
Once the new subscriber is created in MailerLite, they will receive a confirmation email. This step is crucial as it ensures that the subscriber confirms their subscription. You can check your email to verify that the confirmation email has been sent successfully.
After confirming the subscription, return to your MailerLite account and check the subscribers’ section to see if the new subscriber appears there. This final check confirms that the entire workflow is functioning correctly, with Pabbly Connect seamlessly facilitating the integration between Systema.io and MailerLite.
In this tutorial, we explored how to integrate Systema.io with MailerLite using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers based on form submissions, ensuring efficiency and seamless communication.
