Learn how to integrate Stripe with GoHighLevel using Pabbly Connect. This tutorial covers all the steps to automate contact management seamlessly. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for Stripe and GoHighLevel Integration
To begin the integration process, access Pabbly Connect by signing up on the official website. Pabbly Connect acts as the central automation tool that facilitates the connection between Stripe and GoHighLevel.
Once signed up, log in to your Pabbly Connect account. From the dashboard, click on the ‘Create Workflow’ button to initiate the setup. You will need to name your workflow appropriately, such as ‘Send Contacts from Stripe to GoHighLevel’. This naming helps in easy identification later.
The next step involves setting up the trigger event in Pabbly Connect. Select Stripe as your trigger application and choose the event ‘Checkout Process Completed’. This event will initiate the workflow whenever a checkout is completed on Stripe.
- Search for Stripe in the trigger application field.
- Select the trigger event as ‘Checkout Process Completed’.
- Copy the provided webhook URL for the next steps.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it will be used to connect your Stripe account. Ensure you copy this URL for the next steps in the Stripe dashboard.
3. Configuring the Webhook in Stripe
Now, navigate to your Stripe dashboard and set up the webhook using the URL obtained from Pabbly Connect. Go to the Developers section, select the Webhooks tab, and click on ‘Add Endpoint’.
- Paste the copied webhook URL into the endpoint URL field.
- Select the event type ‘checkout.session.completed’ to trigger the workflow correctly.
- Click on ‘Add Events’ to finalize the webhook setup.
This setup allows Stripe to send the necessary data to Pabbly Connect whenever a checkout is completed. Make sure to save the changes in your Stripe settings.
4. Testing the Integration and Capturing Data
With the webhook configured, it’s time to test the integration. Using the test payment link from Stripe, perform a test checkout. Fill in the required customer details and complete the payment process.
Once the test payment is completed, return to Pabbly Connect to confirm that the data has been captured. You should see the event type and customer details populated in the response section of your workflow.
5. Creating Contacts in GoHighLevel
The final step is to set up the action in Pabbly Connect to create contacts in GoHighLevel. Select Lead Connector as your action application and choose ‘Create Contact’ as the action event.
Map the fields from the Stripe response to the corresponding fields in GoHighLevel, such as first name, last name, and email. After mapping the required fields, click on ‘Save and Send Test Request’ to create the contact. You should see the new contact appear in your GoHighLevel account.
In this tutorial, we successfully integrated Stripe with GoHighLevel using Pabbly Connect. This automation simplifies contact management by automatically adding new contacts from Stripe checkouts into GoHighLevel, enhancing your business operations.
