1. Accessing Pabbly Connect for Stripe and Trello Integration
To begin the integration between Stripe and Trello, first, access Pabbly Connect. This platform is essential for automating workflows. Sign up or log in to your Pabbly Connect account to get started.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find the option to create a new workflow. This is where the magic happens, allowing you to connect Stripe and Trello seamlessly.
In this step, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button. Name your workflow something like ‘Stripe to Trello Integration’ for easy identification.
After naming your workflow, you will be prompted to choose a trigger application. Select Stripe as your trigger application. This setup is crucial as it tells Pabbly Connect to listen for new customer events in Stripe.
3. Setting Up the Stripe Trigger in Pabbly Connect
Now, configure the Stripe trigger by selecting the event type. Choose ‘New Customer’ as the event to trigger your workflow. This means every time a new customer is added in Stripe, Pabbly Connect will initiate the next steps automatically.
Once you have selected the event type, click on ‘Save and Send Test Request’. This step helps ensure that Pabbly Connect is correctly receiving data from Stripe. You will see a success message once the test is successful, confirming the connection.
4. Adding Trello as the Action Application
Next, it’s time to add Trello as the action application in your Pabbly Connect workflow. Click on the ‘+’ icon to add an action step. Choose Trello from the list of applications.
In the action event, select ‘Create Card’. This step will allow Pabbly Connect to create a new card in Trello whenever a new customer is added in Stripe. Fill in the required fields such as the card title, description, and other relevant information.
5. Testing the Integration Between Stripe and Trello
After setting up the action in Trello, it’s important to test the entire integration. Click on ‘Save and Send Test Request’ in the Trello action step. This will create a test card in Trello based on the customer data received from Stripe.
Check your Trello board to confirm that the card has been created successfully. If everything works as expected, your integration is complete! This automation will now run in the background, creating Trello cards instantly when a new customer is added in Stripe, all managed through Pabbly Connect.
In this tutorial, we showed you how to use Pabbly Connect to integrate Stripe and Trello, enabling you to instantly create cards in Trello when a new customer is added in Stripe. This automation saves time and enhances productivity.
