1. Integrate Stripe with Make to Instantly Create Subscriber
Integrating Stripe with Make allows you to instantly create a subscriber in AWeber when a new customer is added in Stripe. To start, visit Make and log in to your account.
Click on the ‘Create Workflow’ button, and name your workflow something like ‘Stripe to AWeber’. This will help you identify the automation you are setting up. Choose Stripe as your app in the trigger settings.
2. Set Up New Customer Trigger in Stripe
In the trigger configuration, select ‘New Customer’ as the event. This action will activate the automation whenever a new customer is created in Stripe.
To connect Stripe to Make, navigate to your Stripe account, go to the ‘Developers’ section, and select ‘Webhooks’. Here, you will add a new endpoint.
3. Add Endpoint URL in Stripe Webhooks
In the webhook settings, you need to input the endpoint URL provided by Make. Copy this URL and paste it into the designated field in your Stripe account.
Make sure to select the event type as ‘Customer Created’ to ensure that the webhook will trigger when a new customer is added in Stripe.
4. Capture Webhook Response in Make
After setting up the webhook, return to Make and click on ‘Capture Webhook Response’. This will allow you to test if the integration is working correctly.
To test, create a dummy customer in Stripe. For example, create a customer named ‘Gilchrist’ with an email address ‘[email protected]’. Once the customer is created, check if Make captures this data.
5. Add Subscriber in AWeber
Now, to add this customer as a subscriber in AWeber, click on the plus button in your Make workflow and select AWeber as the action app.
Choose the action ‘Add a Subscriber’. Connect your AWeber account and map the required fields such as full name and email address from the captured Stripe data. For instance, map the name ‘Gilchrist’ and the email ‘[email protected]’.
6. Test the Integration
After mapping, click on ‘Save and Send Test Request’ to ensure that the subscriber is added to your AWeber list. Check your AWeber account to confirm that the new subscriber appears correctly.
Repeat this process by creating another dummy customer, such as ‘Lisa Collin’ with the email ‘[email protected]’, to verify that your integration works seamlessly.
Integrating Stripe and AWeber using Make allows you to instantly create subscribers when customers are added. This automation enhances your email marketing efforts efficiently.
