Learn how to automatically post from Stackby to Pinterest using Pabbly Connect. This detailed tutorial covers setup steps and integration processes. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin automating your Pinterest posts from Stackby, the first step is to set up Pabbly Connect. Start by logging into your Pabbly Connect account. If you don’t have an account, you can create one easily through the link provided in the description.
Once logged in, navigate to the dashboard and click on the ‘Create Workflow’ button. Name your workflow something descriptive, like ‘Create Pins in Pinterest from Stackby Automatically’, and click on the ‘Create’ button to proceed.
Next, you need to configure the trigger for your workflow in Pabbly Connect. Click on the ‘Choose App’ field and select Stackby as your trigger application. The trigger event will be set to ‘New Row’, which means the workflow will activate whenever a new row is added in Stackby.
  • Select Stackby as your trigger application.
  • Choose ‘New Row’ as the trigger event.
  • Click on ‘Connect’ to establish a connection.
After setting this up, you will need the API key from Stackby. Log into your Stackby account, navigate to the account settings, and copy your API key. Paste this key back into Pabbly Connect to complete the connection.
3. Fetching Data from Stackby
Once the connection is made, the next step is to fetch the data from your Stackby table. You will need to select the workspace and stack where your data is stored. Choose the appropriate workspace and select the stack that contains your pin data. using Pabbly Connect
After selecting your stack, you will choose the table where the pin information is stored. Click on ‘Save and Send Test Request’ to fetch a sample of the data. This data will include the title, image URL, and description of your pin.
4. Setting Up the Action to Create a Pin in Pinterest
Now that you have the data from Stackby, it’s time to set up the action in Pabbly Connect to create a pin on Pinterest. Click on the action step and select Pinterest as your action application. Choose ‘Create Pin’ as the action event.
  • Select Pinterest as your action application.
  • Choose ‘Create Pin’ as the action event.
  • Connect to your Pinterest account.
Once connected, select the board where you want to post the pin and map the data fields from Stackby to the corresponding fields in Pinterest. This includes mapping the image URL, title, and description. Finally, click on ‘Save and Send Test Request’ to create the pin.
5. Finalizing the Automation Process
After successfully creating a pin, you can check your Pinterest board to see the new pin created from Stackby data. This automation is now fully functional, meaning you only need to update your Stackby rows, and Pabbly Connect will handle the rest.
To summarize, you have set up a trigger in Pabbly Connect for new rows in Stackby, fetched the relevant data, and configured the action to create pins in Pinterest. This seamless integration saves you time and ensures your Pinterest account is updated automatically.
By utilizing Pabbly Connect, you can enhance your productivity and streamline your social media management. Start automating your workflows today!
