Learn how to use Pabbly Connect to integrate Shopify and Smaily, enabling automatic subscriber creation from new Shopify orders. Follow this detailed tutorial for seamless integration.
To start integrating Shopify with Smaily, first access Pabbly Connect. Open your web browser and type in Pabbly.com, then press enter to reach the Pabbly homepage.
Once on the Pabbly website, hover over the products section and select Pabbly Connect. From there, click on the ‘Sign In’ button to access your dashboard. If you don’t have an account, you can create one for free in just a couple of minutes.
Now that you are logged into Pabbly Connect, you need to create a new workflow. Click the ‘Create Workflow’ button located in the top right corner of your dashboard.
- Give your workflow a name, such as ‘Shopify to Smaily’.
- Select Shopify as the app for the trigger.
- Choose ‘New Order’ as the trigger event.
After naming your workflow and selecting the appropriate trigger, click on ‘Create’ to proceed. This sets up the initial stage of your integration.
3. Setting Up Shopify Webhook to Capture New Orders
Next, you need to set up a webhook in your Shopify account to capture new orders. Navigate to your Shopify admin panel, click on ‘Settings’ at the bottom left, and then select ‘Notifications’.
- Scroll down to find the Webhooks section and click on ‘Create a Webhook’.
- Set the event to ‘Order Creation’ and keep the format as JSON.
- Paste the webhook URL from Pabbly Connect into the URL field.
After saving the webhook, Pabbly Connect will be ready to capture data whenever a new order is created in Shopify.
4. Mapping Data to Smaily for Subscriber Creation
Once Pabbly Connect captures the new order data, the next step is to map this data to create a subscriber in Smaily. In your Pabbly Connect workflow, click the plus button to add an action event, and select Smaily.
Choose ‘Add or Update Subscriber’ as the action event. Connect your Smaily account by entering your username, password, and subdomain. Map the email field from Shopify to the email field in Smaily.
After completing the mapping, click on ‘Save and Send Test Request’ to ensure that the subscriber is added to Smaily successfully.
5. Testing the Integration Between Shopify and Smaily
To verify that your integration works correctly, create a new test order in Shopify. Enter dummy customer details and complete the order process. Once the order is placed, Pabbly Connect should capture this data and reflect it in Smaily as a new subscriber.
Check your Smaily account to confirm that the subscriber has been added. If everything is set up correctly, you will see the new subscriber listed with the email provided during the test order.
This integration means that every time a new order is created in Shopify, a corresponding subscriber will be automatically created in Smaily, streamlining your email marketing efforts.
Using Pabbly Connect to integrate Shopify and Smaily allows for seamless subscriber management. Automate your workflows and enhance your email marketing strategy by setting up this integration today.
