Learn how to automate adding new subscribers from Sendy to Mautic using Pabbly Connect with this step-by-step tutorial. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Sendy with Mautic, you must first access Pabbly Connect. Open your browser and navigate to Pabbly.com/connect. If you already have an account, simply sign in; otherwise, sign up for free, which includes 100 free tasks every month.
Once logged in, you will see your dashboard. Click on Pabbly Connect to begin creating a new workflow. This platform allows you to automate tasks between different applications seamlessly, making it the central hub for this integration.
After accessing Pabbly Connect, click on the Create Workflow button. Name your workflow something descriptive, like ‘Sendy to Mautic Automation’. This name will help you identify the workflow later.
- Click on Create to proceed.
- You will see two windows: Trigger and Action.
- Select Sendy as the trigger application.
In the Trigger Event dropdown, choose New Subscriber. This event will initiate the automation process whenever a new subscriber is added in Sendy. Pabbly Connect will generate a webhook URL that you will need to connect to your Sendy account.
3. Setting Up Sendy to Work with Pabbly Connect
To connect Sendy to Pabbly Connect, copy the generated webhook URL. Now, log in to your Sendy account and navigate to the settings menu. Under the Connect section, create a new rule that triggers on a new subscription.
- Select the list you want to connect, for example, ‘Mautic List’.
- Paste the webhook URL into the Trigger Webhook field.
- Click Add to save the rule.
With this setup, every time a new subscriber is added in Sendy, Pabbly Connect will receive the data via the webhook, allowing for seamless integration with Mautic.
4. Configuring Mautic to Receive Subscribers
Next, you need to configure Mautic to receive the subscriber data from Pabbly Connect. In the Action Event section, select Create or Update Contact. This action will ensure that the subscriber is added as a contact in Mautic.
To connect Mautic, provide your Mautic username, password, and the base URL of your Mautic installation. Make sure the API is activated in your Mautic settings. Once connected, map the fields from Sendy to Mautic, ensuring that the first name, last name, and email are correctly assigned.
After setting up the integration, it’s crucial to test it to ensure everything is functioning as expected. Go back to Sendy and add a test subscriber using the subscription form. Once you subscribe, Pabbly Connect will receive the new subscriber data.
Check the Pabbly Connect dashboard to see if the new subscriber details appear. Verify that the contact is created in Mautic with the correct information.
If the test is successful, the automation is now fully operational. Every new subscriber added in Sendy will automatically be reflected as a contact in Mautic, streamlining your email marketing efforts.
In this tutorial, we demonstrated how to automate adding new subscribers from Sendy to Mautic using Pabbly Connect. This integration simplifies your workflow and ensures your email lists are always up to date. By leveraging Pabbly Connect, you can save time and enhance your email marketing efficiency.
