Learn how to seamlessly add subscribers to Sendinblue using Fluent Forms submissions with Pabbly Connect. Follow our step-by-step tutorial for easy integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Understanding the Integration of Fluent Forms and Sendinblue via Pabbly Connect
The integration of Fluent Forms and Sendinblue can be achieved using Pabbly Connect. Fluent Forms is a WordPress plugin used for creating forms, while Sendinblue is an email marketing platform. Through this integration, you can automatically add subscribers to your Sendinblue contact list whenever a user submits a form created with Fluent Forms.
By using Pabbly Connect, you eliminate the need for manual data entry, allowing you to efficiently manage your email marketing efforts. This automation ensures that all form submissions are captured and added to your Sendinblue list, streamlining your marketing processes.
2. Setting Up Pabbly Connect for Integration
To start the integration, access Pabbly Connect by visiting their website. If you are a new user, you will need to sign up for a free account, which provides you with 100 tasks monthly. Existing users can simply log in to their account to access the dashboard.
Once logged in, follow these steps to create a new workflow in Pabbly Connect:
- Click on the plus sign to create a new workflow.
- Name your workflow, for example, ‘Fluent Forms to Sendinblue Integration’.
- Click on create to proceed.
Now you will see the trigger and action windows where you can set up the integration.
3. Configuring Fluent Forms with Pabbly Connect
In the trigger window, select Fluent Forms as the application and choose the trigger event as ‘New Form Submission’. This will allow Pabbly Connect to capture data whenever a form is submitted. You will be provided with a webhook URL that needs to be added to your Fluent Forms settings.
To configure Fluent Forms, navigate to your WordPress dashboard and select Fluent Forms. Choose the form you want to integrate and scroll down to the settings option. Here, select the WP Webhooks and click on the ‘Send Data’ option. Add a new webhook URL by pasting the URL from Pabbly Connect and save the settings.
After setting up the webhook in Fluent Forms, it’s time to test the integration. Fill out the form using test data, such as a first name, last name, email address, mobile number, and gender. Once submitted, Pabbly Connect will receive the form data and display it in the dashboard.
To finalize the integration, proceed to the actions tab in Pabbly Connect and select Sendinblue as the application. Choose the action event as ‘Create or Update Contact’. Connect your Sendinblue account by entering the API key, which can be generated from your Sendinblue dashboard. After connecting, map the fields from the form submission to the corresponding fields in Sendinblue.
5. Finalizing the Automation and Ensuring Functionality
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ in Pabbly Connect. This will send the test data to your Sendinblue account. Refresh your Sendinblue contacts list to verify that the new subscriber has been added successfully.
After confirming that the integration works as intended, save your workflow in Pabbly Connect. This will ensure that every time a new submission is made in Fluent Forms, the details will automatically be added to your Sendinblue contact list, enhancing your marketing efficiency.
In this tutorial, we explored how to integrate Fluent Forms with Sendinblue using Pabbly Connect. By setting up this automation, you can streamline your email marketing efforts and ensure that all form submissions are captured effectively. This integration not only saves time but also enhances your ability to reach out to customers with targeted marketing campaigns.
