Learn how to integrate ScoreApp with your Telegram Channel using Pabbly Connect to automate new registrant notifications. Step-by-step tutorial included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
In this section, we will discuss how to access Pabbly Connect to set up the integration between ScoreApp and Telegram. Start by visiting the Pabbly Connect homepage. If you are an existing user, sign in. New users can sign up for free to get started with 100 tasks monthly.
Once signed in, navigate to the ‘All Applications’ page. Click on Pabbly Connect and select ‘Access Now’ to reach your dashboard. Here, you will create a new workflow for sending ScoreApp new registrant details to your Telegram channel.
To create a new workflow in Pabbly Connect, locate the ‘Create Workflow’ button in the top right corner of your dashboard. Click it and enter a name for your workflow, such as ‘Send ScoreApp New Registrants Details in Telegram Channel.’ You can also choose a folder to save this workflow.
- You will be directed to a window for setting up the trigger and action.
In this window, you will define the trigger application as ScoreApp and the action application as Telegram. This setup is crucial for enabling the automation of sending new registrant details to your Telegram channel.
Now we will configure the trigger and action for our workflow in Pabbly Connect. Set ScoreApp as the trigger application and select the event ‘Lead Signed Up.’ This event will activate the workflow whenever a new user registers through ScoreApp.
Next, set Telegram as your action application. Choose the action event as ‘Send a Text Message’. This setup will allow you to send a message to your Telegram channel whenever a new registration occurs.
- Ensure to establish a connection between ScoreApp and Pabbly Connect by using the provided webhook URL.
- Follow the instructions to connect your ScoreApp account with Pabbly Connect.
Once connected, Pabbly Connect will wait for a webhook response, indicating that the setup is complete and ready for testing.
4. Testing the Integration with ScoreApp
To test the integration, you need to create a test submission in ScoreApp. Fill in the lead form with dummy details such as first name, last name, and email. After submission, Pabbly Connect will capture the response.
Verify that the details received in Pabbly Connect match the information submitted. This step confirms that the trigger is functioning correctly and the data is being captured as expected.
Once the test is successful, you can proceed to send messages to your Telegram channel. This ensures that every new registration will be reflected in your channel in real-time.
5. Finalizing Telegram Setup in Pabbly Connect
Now, you will finalize the Telegram setup in Pabbly Connect. Start by creating a bot in Telegram using BotFather. Copy the bot token provided after creating the bot and paste it into Pabbly Connect to establish the connection.
Next, you will need to specify the chat ID of the Telegram channel where the messages will be sent. After mapping the necessary fields, such as name and email from the ScoreApp response, ensure to give your bot admin access to the channel.
Click on ‘Save and Send Test Request’ in Pabbly Connect to verify that the message is sent successfully. Check your Telegram channel to confirm receipt of the message.
Once confirmed, your integration is complete. Now, every new registration in ScoreApp will automatically send details to your Telegram channel through Pabbly Connect.
This tutorial has guided you through integrating ScoreApp with your Telegram channel using Pabbly Connect. By following these steps, you can automate the process of sending new registrant details directly to your team, enhancing communication and efficiency.
