Learn how to integrate Razorpay with GoToTraining using Pabbly Connect. This guide covers every step to automate your registration process seamlessly. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Overview of Pabbly Connect for Razorpay and GoToTraining Integration
In this section, we will explore how to use Pabbly Connect to integrate Razorpay and GoToTraining. This integration automates the registration of participants whenever a payment is successfully captured through Razorpay.
By utilizing Pabbly Connect, businesses can streamline their registration processes, ensuring that every payment leads to an automatic registration in GoToTraining. This eliminates manual work and enhances operational efficiency.
2. Accessing Pabbly Connect for Integration Setup
To begin the integration, you need to access Pabbly Connect. Start by navigating to the Pabbly website and logging into your account. If you are a new user, you can sign up for a free account to explore the features.
Once logged in, click on the ‘Access Now’ button to enter your Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Enter a relevant name for your workflow, such as ‘Create GoToTraining Registrant on Razorpay Payment,’ and select a folder to save it in.
In this step, you will set up the trigger for your integration using Pabbly Connect. Select Razorpay as your trigger application and choose the ‘Payment Captured’ event. This will initiate the workflow whenever a payment is successfully processed.
- Search for Razorpay in the trigger application list.
- Select the ‘Payment Captured’ event.
Next, you need to integrate this webhook URL into your Razorpay account. Log into Razorpay, navigate to the developer section, and add a new webhook under the settings. Paste the copied URL and select ‘Payment Captured’ from the active events. This step establishes the connection between Razorpay and Pabbly Connect.
4. Testing the Webhook Connection
After setting up the webhook, it’s essential to test the connection to ensure everything is working correctly. Make a test payment through Razorpay using the payment page you set up earlier. Fill in the required details and complete the payment process.
Once the payment is successful, return to your Pabbly Connect workflow. You should see that the webhook has captured the payment details, including the first name, last name, email, and payment method. This confirms that Razorpay is successfully sending data to Pabbly Connect.
5. Creating a Registrant in GoToTraining
Now that the webhook is tested and confirmed, it’s time to create a registrant in GoToTraining. In Pabbly Connect, add an action step and select GoToTraining as your action application. Choose the ‘Create Registrant’ event.
- Connect your GoToTraining account to Pabbly Connect.
- Map the fields from the Razorpay payment details to the GoToTraining registrant fields.
- Test the action to ensure the registrant is created successfully.
After mapping the necessary fields and testing the action, you will see a new registrant created in your GoToTraining account. This step finalizes the integration, allowing automatic registrations for every successful payment captured by Razorpay.
In conclusion, using Pabbly Connect to integrate Razorpay with GoToTraining enables a seamless registration process for participants. By automating the workflow, businesses can save time and reduce manual errors, ensuring efficient operations.
This tutorial has guided you through each step of the integration process, from accessing Pabbly Connect to creating registrants in GoToTraining. Implementing this automation can significantly enhance your training session management.
