Learn how to automate Zoom registrations for successful Razorpay payments using Pabbly Connect. Follow our step-by-step tutorial for seamless integration! Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
Setting Up Pabbly Connect for Integration
To integrate Razorpay payments with Zoom Webinar, start by accessing Pabbly Connect. This platform allows you to automate the process seamlessly. Begin by logging into your Pabbly Connect account and navigating to the dashboard.
Once on the dashboard, click on the ‘Create New Workflow’ button. Name your workflow something relevant, like ‘Razorpay to Zoom Integration’. This step will set the foundation for your automated process.
Configuring Razorpay as the Trigger in Pabbly Connect
Next, you need to configure Razorpay as the trigger application in Pabbly Connect. Select Razorpay from the list of applications and choose the event that will trigger the workflow, which is typically ‘Payment Captured’.
After selecting the trigger, you will be prompted to connect your Razorpay account. Enter your API keys and authenticate the connection. This allows Pabbly Connect to receive data from Razorpay when a payment is successfully made.
Setting Up Zoom as the Action Application
Once Razorpay is configured, it’s time to set up Zoom as the action application in Pabbly Connect. Choose Zoom from the app list and select the action event, which is ‘Add Registrant’.
Now, connect your Zoom account by providing the necessary credentials. You will need to authorize Pabbly Connect to access your Zoom account, allowing it to add registrants automatically.
- Select the Zoom Webinar you want to add registrants to.
 - Map the required fields from Razorpay to Zoom, such as the name and email of the payer.
 - Test the integration to ensure everything is working correctly.
After configuring these settings, you will be able to automatically add registrants to your Zoom Webinar after a successful payment is made through Razorpay.
Testing the Integration
With both Razorpay and Zoom set up in Pabbly Connect, it’s crucial to test the integration. Perform a test payment through Razorpay to see if the registrant is added to your Zoom Webinar as expected.
Monitor the Pabbly Connect dashboard for any errors during the test. If everything works smoothly, you will see the registrant’s details appear in your Zoom account. This confirms that the integration is functioning correctly.
Integrating Razorpay payments with Zoom Webinar using Pabbly Connect automates the registration process seamlessly. By following these steps, you can ensure that every successful payment leads to a new registrant in your Zoom Webinar.
