Learn how to seamlessly integrate Razorpay and Thinkific using Pabbly Connect to enroll users automatically. Follow this detailed tutorial for effective automation. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin integrating Razorpay with Thinkific, you first need to access Pabbly Connect. Visit the Pabbly website and navigate to the Pabbly Connect section.
If you are a new user, click on the ‘Sign Up for Free’ button to create your account. Existing users can simply log in. Once logged in, you will be directed to the Pabbly Connect dashboard, where you can create a new workflow.
In this step, you will create a workflow to automate the enrollment process. Click on the plus sign to create a new workflow and name it ‘Add and Enroll Thinkific Users in Bundle for New Razorpay Payment’. using Pabbly Connect
Now, you will see a trigger window and an action window. The trigger is the event that starts the automation, and the action is what happens as a result. Set Razorpay as the application and select the trigger event as ‘Payment Captured’.
- Select Razorpay as the application.
- Choose ‘Payment Captured’ as the trigger event.
After this, you will need to set up the webhook in your Razorpay account by pasting the copied URL into the webhook settings.
3. Configure the Webhook in Razorpay
To capture payment details, configure the webhook in Razorpay. Go to your Razorpay account settings and find the webhooks section. Click on ‘Add New Webhook’ and paste the URL from Pabbly Connect.
Make sure to enable the event for ‘Payment Captured’. This will ensure that every time a payment is made, Razorpay sends the details to Pabbly Connect. After saving, return to Pabbly Connect, where it will now wait for the webhook response.
- Navigate to Razorpay settings and select ‘Webhooks’.
- Click on ‘Add New Webhook’.
- Paste the webhook URL and enable ‘Payment Captured’.
Once the webhook is set up, make a test payment to capture the response in Pabbly Connect.
4. Search for Thinkific User in Pabbly Connect
After capturing the payment details, the next step is to check if the user already exists in Thinkific. In the action step, select Thinkific as the application and choose ‘Search User’ as the action event. using Pabbly Connect
Connect your Thinkific account by entering the subdomain from your Thinkific URL. After creating the connection, you will need to map the email address from the Razorpay payment details to search for the user. If the user does not exist, you will create a new user.
Select Thinkific as the application. Choose ‘Search User’ as the action event. Map the email address from Razorpay to search for the user.
Once you check if the user exists, you can proceed to either create a user or enroll them in the course bundle.
5. Enroll User in Bundle Using Pabbly Connect
Finally, you will enroll the user in the specified course bundle. If the user does not exist, create a new user in Thinkific and then enroll them in the bundle. If the user exists, simply enroll them in the bundle. using Pabbly Connect
To do this, select Thinkific again and choose the ‘Enroll User in Bundle’ action event. Map the required fields, including the user ID, and specify the bundle name. You can set the activation and expiration dates for the enrollment as well.
Choose ‘Enroll User in Bundle’ as the action event. Map the user ID and select the bundle name. Set activation and expiration dates for the enrollment.
Once everything is set, save the workflow. You can now test the entire integration to ensure that users are enrolled in Thinkific whenever a payment is captured in Razorpay.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Razorpay and Thinkific effectively. By following these steps, you can automate the enrollment of users into your courses seamlessly. This integration not only saves time but also enhances user experience by ensuring immediate access to course materials after payment.
