Learn how to seamlessly integrate Razorpay with Circle.so using Pabbly Connect to manage your paid members effectively. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To start integrating Razorpay with Circle.so, you first need to access Pabbly Connect. Navigate to your browser and type in pablp.com/cc Connect. This will redirect you to the Pabbly Connect homepage where you can either sign in or sign up.
If you do not have an account, signing up is free and offers 100 free tasks each month. Once logged in, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow something relevant, such as ‘Razorpay to Circle’.
In this step, you will set up the trigger that initiates the workflow. Select Razorpay as your trigger application and choose the ‘Payment Captured’ event. This event will activate whenever a payment is made through Razorpay. using Pabbly Connect
- Select Razorpay from the list of applications.
- Choose ‘Payment Captured’ as the event.
Next, go to your Razorpay dashboard, navigate to the settings, and click on ‘Webhooks’. Here, add a new webhook and paste the copied URL. Make sure to select the ‘Payment Captured’ event before saving the webhook settings.
3. Making a Dummy Payment to Test the Integration
To test the integration, you need to make a dummy payment. Use the payment page you created in Razorpay and fill in the required details such as name, email, and payment information. For this example, use the name ‘Ryan Glasgow’ and the email ‘[email protected]’. using Pabbly Connect
Once you fill in the details, click on ‘Pay’ to complete the transaction. After the payment is processed, you should see a webhook response in Pabbly Connect that confirms the payment details, including the name and email.
4. Tagging Members in Circle Using Pabbly Connect
Now that you have successfully captured the payment, the next step is to tag the member in Circle.so. In Pabbly Connect, select Circle as the action application and choose the ‘Tag a Member’ action event. Connect your Circle account by entering the required API token and host URL. using Pabbly Connect
- Enter the host URL from your Circle account.
- Paste the API token you generated from Circle.
- Map the email and Community ID from the webhook response.
For the member tag, select ‘Paid User’ to identify them as a paying member. After configuring these settings, click on ‘Save and Send Test Request’ to verify that the tag has been successfully added to the member’s profile in Circle.
5. Conclusion
In this tutorial, you learned how to use Pabbly Connect to integrate Razorpay with Circle.so. This integration allows you to automatically tag paid members in your Circle community, streamlining your member management process.
By following the steps outlined, you can efficiently manage your community and enhance member engagement. Automation through Pabbly Connect not only saves time but also improves the accuracy of your member tagging process. Start using Pabbly Connect today to simplify your workflows!
