Learn how to integrate Razer Pay with Google Drive using Pabbly Connect to automate payment processing and folder creation. Follow this detailed tutorial for seamless integration.
To start integrating Razer Pay with Google Drive, access Pabbly Connect first. Visit the Pabbly Connect website and either sign in or create a new account if you haven’t already.
Once logged in, you will be directed to the dashboard of Pabbly Connect. This is where you can create and manage your workflows. Click on the ‘Create Workflow’ button to begin setting up the integration.
2. Setting Up Razer Pay as the Trigger in Pabbly Connect
In this step, we will set up Razer Pay as the trigger application in Pabbly Connect. Choose Razer Pay from the trigger application options. The trigger event will be ‘Payment Capture’.
Next, connect your Razer Pay account by following the instructions provided by Pabbly Connect. This involves copying a webhook URL and adding it to your Razer Pay account settings under the webhook section. Follow these steps:
- Open Razer Pay and navigate to Account Settings.
- Select the Webhooks option and add a new webhook.
- Paste the copied URL and select ‘Payment Capture’ as the event.
After saving the webhook, return to Pabbly Connect to test the connection. This will confirm that the trigger is set up correctly and is ready to capture payment data.
3. Creating a Google Drive Folder for Payments
After setting Razer Pay as the trigger, the next step is to create a folder in Google Drive. In Pabbly Connect, add an action step and select Google Drive as the action application. Choose the action event ‘Create Sub Folder’.
Connect your Google Drive account to Pabbly Connect, and select the folder where you want to create the new subfolder. For the subfolder name, use mapping to dynamically set it to the user’s name from the payment details captured earlier. Follow these steps:
- Select the PHP Programming Course folder in Google Drive.
- Map the user’s first and last name to create a personalized folder.
After completing these steps, test the action to ensure the folder is created successfully in Google Drive.
4. Sharing the Google Drive Folder with the User
The final step in this integration process is to share the newly created Google Drive folder with the user. In Pabbly Connect, add another action step and select Google Drive again. This time, choose the action event ‘Share a File or Folder by ID’.
Map the folder ID of the newly created folder and the email address of the user to whom you want to share the folder. Set the permission to ‘Can View’. After mapping, save your settings and send a test request to ensure the folder is shared correctly.
With this setup, whenever a payment is captured via Razer Pay, a new folder will be created in Google Drive and shared with the customer, streamlining the process and saving time.
5. Conclusion
In this tutorial, we successfully integrated Razer Pay with Google Drive using Pabbly Connect. By automating the creation and sharing of folders, we enhanced efficiency in managing payment records. This integration allows for seamless operations and better customer experience.
By following the outlined steps, you can replicate this process for your own workflows, leveraging the power of Pabbly Connect to connect various applications effectively.
