Learn how to automate your email marketing by integrating PipeDrive with AWeber using Pabbly Connect. Follow our detailed tutorial for seamless setup. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating PipeDrive with AWeber, you first need to access Pabbly Connect. This powerful automation tool allows you to connect various applications effortlessly, enhancing your workflow.
Begin by logging into your Pabbly Connect account. If you don’t have an account yet, you can create one in just a couple of minutes. Once logged in, you will be directed to the Pabbly Connect dashboard.
After accessing the dashboard, the next step is to create a new workflow. Click on the ‘Create Workflow’ button to initiate this process. You will then be prompted to name your workflow, which can be anything relevant to your integration. using Pabbly Connect
  • Click on ‘Create Workflow’ in the Pabbly Connect dashboard.
  • Enter a suitable name for your workflow.
  • Click on ‘Save’ to proceed.
Once your workflow is created, you can set the trigger event. For this integration, select PipeDrive as the trigger application and choose ‘New Deal’ as the event. This setup will ensure that whenever a new deal is created in PipeDrive, the workflow will be triggered automatically.
3. Fetching Customer Details from PipeDrive
With your workflow set up, the next step is to fetch customer details from PipeDrive. This is crucial as you need the customer’s information to add them as a subscriber in AWeber. In Pabbly Connect, map the necessary fields to capture customer details accurately.
Ensure that the current person ID is mapped correctly. This mapping is essential because it allows Pabbly Connect to retrieve the correct customer information every time a new deal is created. After mapping, click on ‘Save and Send Test Request’ to verify that the details are being fetched correctly.
4. Adding Customer to AWeber
Now that you have the customer details, the next step is to connect AWeber to your workflow in Pabbly Connect. Choose AWeber as the action application and select ‘Add Subscriber’ as the action event. This action will automatically add the customer to your AWeber mailing list.
  • Connect to your AWeber account by clicking ‘Connect’.
  • Authorize Pabbly Connect to access your AWeber account.
  • Map the customer’s email and name fields from the previous step.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to confirm that the integration works correctly. You should see the customer added to your AWeber subscriber list.
5. Conclusion: Automate Your Workflow with Pabbly Connect
By following these steps, you can seamlessly integrate PipeDrive with AWeber using Pabbly Connect. This automation allows you to add customers to your mailing list automatically whenever a new deal is created, enhancing your email marketing efforts.
Setting up this workflow requires no coding knowledge, making it accessible for everyone. Once configured, you can focus on your business while Pabbly Connect handles the automation in the background.
In summary, integrating PipeDrive with AWeber through Pabbly Connect streamlines your customer relationship management and email marketing processes. Start using this automation today to enhance your business efficiency.
