Learn how to seamlessly integrate Pabbly Connect with ActiveCampaign using Pabbly Connect in this step-by-step tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Setting Up Pabbly Connect for ActiveCampaign Integration
To integrate Pabbly Form Builder with ActiveCampaign, the first step is to access Pabbly Connect. Begin by logging into your Pabbly Connect account to reach the dashboard. If you don’t have an account yet, you can create one using the link in the description, which offers 100 free automation tasks every month.
Once you are on the dashboard, click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this integration, name it something like ‘Pabbly Form Builder to ActiveCampaign Automation’ and click on the ‘Create’ button. This sets the foundation for your workflow using Pabbly Connect.
The next step involves setting up the trigger for your workflow in Pabbly Connect. Select ‘Pabbly Form Builder’ as your trigger application. The trigger event will be ‘New Form Submission’. This event will initiate the workflow every time a new submission is made.
- Select the trigger application as Pabbly Form Builder.
- Choose the trigger event as New Form Submission.
- Copy the provided webhook URL for later use.
After selecting the trigger, you will receive a webhook URL. This URL is essential for connecting to Pabbly Form Builder. Copy this URL, as you will need to paste it into your form settings in Pabbly Form Builder.
3. Configuring Pabbly Form Builder with Webhook
Now, navigate to your Pabbly Form Builder dashboard. Here, select the form you want to use for collecting leads, such as the ‘Connect With Us’ form. Click on the ‘Integrations’ option in the left panel to set up the webhook. using Pabbly Connect
- Select your desired form from the forms menu.
- Click on ‘Create Webhook’ and paste the webhook URL from Pabbly Connect.
- Save the webhook to activate it.
After saving, the webhook should indicate that it is waiting for a response. To test this, you will need to submit the form with test data. Once the form is submitted, check back in Pabbly Connect to see if the data has been captured successfully.
4. Setting Up Action in Pabbly Connect to Add Contacts to ActiveCampaign
With the trigger now set, the next step is to configure the action in Pabbly Connect. Select ‘ActiveCampaign’ as your action application and choose the action event as ‘Create a Contact’. This will allow you to add the lead information directly into your ActiveCampaign account.
To connect to ActiveCampaign, you will need your API key and URL. Navigate to the settings in your ActiveCampaign dashboard, find the ‘Developer’ section, and copy the API key and URL. Paste these into the respective fields in Pabbly Connect to establish the connection.
5. Mapping Fields to Create Contacts in ActiveCampaign
Now that you have established a connection with ActiveCampaign through Pabbly Connect, it’s time to map the fields from the form submission to the contact fields in ActiveCampaign. You will need to map the email, first name, last name, and phone number accordingly.
Map the email field from the Pabbly Form Builder data. Map the first name and last name fields appropriately. Ensure the phone number is also mapped correctly.
After mapping the fields, click on ‘Save and Send Test Request’ to test the integration. If everything is set up correctly, a new contact should appear in your ActiveCampaign contacts list. This confirms that your automation is working seamlessly.
In this tutorial, we demonstrated how to integrate Pabbly Form Builder with ActiveCampaign using Pabbly Connect. This automation allows for efficient lead collection and management without manual input. By following these steps, you can streamline your workflow and enhance productivity.
