Learn how to seamlessly integrate Pabbly Connect leads with GoHighLevel using Pabbly Connect in this detailed tutorial. Step-by-step guide included! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating Pabbly Form Builder with GoHighLevel, the first step is to access Pabbly Connect. Open your browser and navigate to Pabbly lp.com/cc. Here, you have the option to sign in if you already have an account or sign up for a new account if you don’t.
Signing up is free and provides you with 100 free tasks each month. Once you log in, click on the ‘Create Workflow’ button to initiate the integration process. This is where Pabbly Connect will facilitate the connection between your applications.
After logging into Pabbly Connect, you will see an option to create a new workflow. Click on ‘Create Workflow’ and give it a name that reflects its purpose, such as ‘Pabbly Form Builder to GoHighLevel Integration’. This title will help you identify the workflow later.
- Select ‘Pabbly Form Builder’ as the trigger application.
Once you have set the trigger, Pabbly Connect will provide you with a webhook URL. This URL is essential for connecting Pabbly Form Builder to your workflow. You will need to copy this webhook URL for the next steps in your integration.
3. Configure Pabbly Form Builder
Now that you have the webhook URL from Pabbly Connect, go to your Pabbly Form Builder dashboard. Select the form you want to use for submissions and navigate to the settings of that form.
- In the settings, look for the ‘Integrations’ tab.
- Click on ‘Create Webhook’ and paste the webhook URL you copied earlier.
- Save the changes to connect your form with Pabbly Connect.
After saving, any new submissions from this form will now trigger the webhook, allowing Pabbly Connect to capture the data and proceed to the next steps in your automation.
4. Set Up GoHighLevel in Pabbly Connect
With the form submissions now connected to Pabbly Connect, the next step is to set up the action in GoHighLevel. In your workflow, select ‘GoHighLevel’ as the action application and choose ‘Create Contact’ as the action event.
You will need to connect your GoHighLevel account by entering the API key. To find your API key, navigate to your GoHighLevel account settings, then to the API Keys section. Copy your API key and paste it into the connection setup in Pabbly Connect.
5. Map Data and Test the Integration
After connecting GoHighLevel, it’s time to map the data from Pabbly Form Builder to GoHighLevel. In the mapping section, fill in the fields with the corresponding data from the form submissions.
Map the first name, last name, and email address from the form. Ensure all required fields in GoHighLevel are filled correctly.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’. If the setup is correct, a new contact will be created in your GoHighLevel account, confirming that Pabbly Connect has successfully integrated your form submissions.
Integrating Pabbly Form Builder with GoHighLevel using Pabbly Connect allows for seamless lead management and automation. This process enhances your marketing efforts by automatically creating contacts from form submissions. Take advantage of this integration to streamline your workflows and improve efficiency.
