Learn how to automate subscriber addition in SendFox using Pabbly Connect with Pagemaker form submissions. Follow this detailed guide for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start using Pabbly Connect for automating subscriber addition in SendFox, first, log in to your Pabbly Connect account. If you don’t have an account, you can create one easily in just a few minutes. After logging in, you’ll reach the dashboard where you can create your automation workflow.
Click on the ‘Create Workflow’ button to initiate the setup. Give your workflow a suitable name, such as ‘Pagemaker to SendFox Automation’. This will help you identify the purpose of the workflow later. Once named, click on the ‘Create’ button to continue.
2. Setting Up Trigger in Pabbly Connect
The next step involves setting up the trigger for your automation. In Pabbly Connect, select ‘Pagemaker’ as your trigger application. The event that initiates the workflow will be a new form submission from your Pagemaker landing page.
- Select ‘Pagemaker’ from the app list.
- Choose the trigger event as ‘Web Configuration’.
- Copy the provided webhook URL for further setup.
After copying the webhook URL, follow the instructions provided by Pabbly Connect to configure this in your Pagemaker application. This will establish the link between the two platforms, allowing data to flow seamlessly.
3. Configuring Pagemaker for Webhook
Now, navigate to your Pagemaker dashboard and select the landing page you wish to work with. Click on the ‘Integrations’ tab on the left-hand side. Here, click on the ‘Add New’ button and select ‘Pabbly’ from the options. using Pabbly Connect
- Paste the copied webhook URL into the designated field.
- Assign a suitable name for the webhook, like ‘SendFox Integration’.
- Click on the ‘Create’ button to finalize the setup.
Once the webhook is created, your Pabbly Connect workflow will show that it is waiting for a response. This indicates that the configuration is correct, and you can now perform a test submission.
To test the integration, you need to fill out the form on your Pagemaker landing page. Open the page and submit a demo entry with a name, last name, and email address. After submitting the form, return to your Pabbly Connect workflow to verify if the data has been captured.
If the test submission is successful, you should see the submitted data reflected in the Pabbly Connect response section. This confirms that Pabbly Connect is correctly receiving data from your Pagemaker form.
5. Adding Subscriber to SendFox via Pabbly Connect
The final step is to add the captured subscriber data to SendFox. In your Pabbly Connect workflow, search for ‘SendFox’ as the action application and select the event as ‘Add Contact to List’. Connect your SendFox account using the personal access token from your SendFox settings. using Pabbly Connect
Choose the list you want to add the subscriber to. Map the fields for first name, last name, and email using the data fetched from the Pagemaker form. Click on ‘Save and Send Test Request’ to finalize the process.
Once you complete this step, the subscriber will be added to your SendFox list automatically, completing the integration process. You can now automate subscriber management efficiently with Pabbly Connect.
In this tutorial, we explored how to automate the addition of subscribers in SendFox using Pabbly Connect and Pagemaker form submissions. This integration streamlines your email marketing efforts, allowing for seamless subscriber management without manual input.
