Learn how to integrate Nish and ConvertKit using Pabbly Connect with this detailed tutorial. Follow the step-by-step process for seamless automation. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start integrating Nish and ConvertKit, first access Pabbly Connect. This platform allows seamless automation between various applications, including Nish and ConvertKit. Begin by visiting the Pabbly Connect homepage.
Once there, you will find options to sign in or create a new account. If you’re a new user, click on ‘Sign Up Free’ to explore the features, while existing users should click ‘Sign In’ to access their dashboards. After logging in, you will be directed to the Pabbly Connect dashboard where you can create workflows.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. This action opens a dialog box where you can name your workflow.
For this integration, name your workflow something descriptive, like ‘Create User in Nish and Subscriber in ConvertKit from Webhook Response.’ You can also select a folder to organize your workflows. After naming, click ‘Create’ to proceed with setting up your automation.
Setting Up the Trigger with Webhook
In this section, we will set up the trigger using Webhook by Pabbly. This is crucial as it allows you to receive data from your Elementor form directly into Pabbly Connect. Select ‘Webhook by Pabbly’ as your trigger application and choose the trigger event as ‘Catch Webhook’.
After selecting the trigger event, you will receive a unique Webhook URL. This URL is essential for connecting your Elementor form to Pabbly Connect. Copy this URL and head to your Elementor account, where you will edit the form you created earlier.
- Open your Elementor form and select the form element.
- Under ‘Actions After Submit’, add ‘Webhook’ as an action.
- Paste the copied Webhook URL into the appropriate field and save your changes.
Once done, your Elementor form is now connected to Pabbly Connect, and you can proceed to test the integration.
Adding User to Nish Integration
Now that the trigger is set up, the next action is to add a user to your Nish account using the data received from the form submission. In Pabbly Connect, select Nish as the action application and choose the event ‘Add User to Course’.
To connect your Nish account, you will need to provide your Nish website URL and API key. These can be found in your Nish account under the settings and integrations section. Once connected, you can map the data from the previous step to the fields required, such as name and email.
- Map the first name and last name from the webhook response to the corresponding fields in Nish.
- Enter the course ID for the course you wish to enroll the user in.
- Click ‘Save and Send Test Request’ to ensure the user is added successfully.
After this step, you should see a confirmation that a user has been created in your Nish account, confirming that the integration works correctly.
Creating Subscriber in ConvertKit
The final step involves adding the same user as a subscriber in your ConvertKit account. Again, in Pabbly Connect, select ConvertKit as your action application and choose the event ‘Add Subscriber to Form’.
Connect your ConvertKit account by entering the API key and API secret, which can be found in your ConvertKit account settings under the developer section. Once connected, select the form you created in ConvertKit where you want to add the subscriber.
Map the first name, last name, email, and mobile number from the webhook response. Click ‘Save and Send Test Request’ to finalize the process.
After completing this step, you should receive a confirmation that a new subscriber has been created in your ConvertKit account, effectively linking your Nish and ConvertKit accounts through Pabbly Connect.
In this tutorial, we demonstrated how to integrate Nish and ConvertKit using Pabbly Connect. By following these steps, you can automate user creation and subscriber management seamlessly. This process not only saves time but also enhances the efficiency of your online course management.
