Learn how to integrate Mailchimp with Instamojo using Pabbly Connect. This step-by-step guide covers all necessary steps for seamless automation. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To integrate Mailchimp with Instamojo, first, you need to access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly.
Visit the official Pabbly Connect website and sign in to your account. If you are a new user, you can sign up for free and receive 100 tasks every month. Once logged in, you will see the dashboard that lists all available applications.
After accessing Pabbly Connect, you need to create a new workflow to connect Instamojo and Mailchimp. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
A dialog box will appear prompting you to enter a name for your workflow. Name it ‘Create Mailchimp Member on Instamojo Sale’ and select the appropriate folder to save it. After this, click the ‘Create’ button to finalize your workflow creation. This sets the stage for integrating the two applications.
  • Enter a descriptive name for the workflow.
  • Select a folder where the workflow will be saved.
Now, you will see two sections labeled ‘Trigger’ and ‘Action’. You will set up the trigger first, which will initiate the workflow.
3. Setting Up the Trigger with Instamojo
The next step involves setting up the trigger in Pabbly Connect. Select ‘Instamojo V1’ as your trigger application and choose the event ‘New Sale’. This configuration means that whenever a new sale occurs in Instamojo, the workflow will be triggered.
Pabbly Connect will provide you with a unique webhook URL. Copy this URL as it will be used to connect Instamojo with Pabbly Connect. Go to your Instamojo account and navigate to the smart page you created for your product.
  • Select ‘Instamojo V1’ as the trigger application.
  • Choose ‘New Sale’ as the trigger event.
Now, edit the smart page settings in Instamojo, go to ‘Webhook’, and paste the copied URL. Ensure you toggle the button to enable the webhook and select ‘Successful Payments’ to capture only successful transactions.
4. Setting Up the Action to Add Member in Mailchimp
Once the trigger is set, it’s time to configure the action step in Pabbly Connect. Select ‘Mailchimp’ as your action application and choose the event ‘Add Member with Custom Fields’. This action will automatically add new customers as members in your Mailchimp account whenever a purchase is made.
Click on the ‘Connect’ button to set up the connection. You will need to provide your Mailchimp API token and data center. To get these, log in to your Mailchimp account, go to your profile, and generate an API key under the ‘Extras’ section.
Select ‘Mailchimp’ as the action application. Choose ‘Add Member with Custom Fields’ as the action event. Provide your Mailchimp API token and data center.
After connecting, map the fields from the previous step to create the member details. This includes the customer’s email, first name, and last name, ensuring that each new sale is recorded in your Mailchimp audience.
5. Finalizing the Automation and Testing
With both the trigger and action steps configured, it’s time to finalize the automation in Pabbly Connect. Test the integration by making a test payment through your Instamojo smart page. This will trigger the workflow and add the member to Mailchimp.
Once the payment is successful, check your Mailchimp account under the ‘All Contacts’ section. You should see the new member added with the details captured during the payment process. This confirms that your automation is working correctly.
By following these steps, you have successfully created an automation process between Instamojo and Mailchimp using Pabbly Connect. This integration streamlines your workflow and enhances your email marketing efforts.
In this tutorial, we explored how to integrate Mailchimp with Instamojo using Pabbly Connect. By automating the addition of new customers as Mailchimp members, you can enhance your email marketing strategy and save valuable time. Embrace automation with Pabbly Connect for a more efficient business process.
