Learn how to integrate MailChimp with ClickFunnels using Pabbly Connect to automate subscriber management effortlessly. Follow this step-by-step tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Introduction to Integration Using Pabbly Connect
In this tutorial, we will explore how to use Pabbly Connect to automatically add subscribers to MailChimp whenever a new contact is created in ClickFunnels. This integration streamlines your workflow, saving you time and effort.
Pabbly Connect acts as the central automation platform that connects ClickFunnels and MailChimp. By setting up this integration, you can ensure that every new contact from ClickFunnels is seamlessly added to your MailChimp subscriber list without any manual intervention.
2. Setting Up Pabbly Connect for ClickFunnels and MailChimp
To begin, navigate to the Pabbly Connect website and sign in to your account. If you don’t have an account, you can sign up for free and receive 100 tasks every month.
Once logged in, click on the ‘Create Workflow’ button and name your workflow, for example, ‘ClickFunnels to MailChimp.’ This will set the stage for your automation process.
  • Select ClickFunnels as the trigger application.
  • Choose ‘New Contact Created’ as the trigger event.
After setting up the trigger, you will need to paste the webhook URL into ClickFunnels to establish the connection. This will allow Pabbly Connect to listen for new contacts created in ClickFunnels.
3. Configuring ClickFunnels Webhook with Pabbly Connect
Next, navigate to your ClickFunnels dashboard. Go to the funnel settings and select the ‘Webhooks’ option. Here, you will create a new webhook.
Click on the ‘Add New Webhook’ button and paste the copied webhook URL into the URL field. Make sure to select ‘Contact Created’ from the events section and set the adapter to JSON. This configuration ensures that ClickFunnels communicates with Pabbly Connect effectively.
  • Select the funnel you want to integrate.
  • Paste the webhook URL in the specified field.
  • Save the webhook settings.
Once the webhook is created, return to Pabbly Connect and check if it is waiting for a webhook response. This indicates that the integration is set up correctly.
4. Testing the Integration of ClickFunnels and MailChimp
To test the integration, you need to add a dummy contact through your ClickFunnels registration form. Once the form is submitted, Pabbly Connect will capture the new contact details.
After submitting the form, return to Pabbly Connect to see if it has received the response with the contact details. If successful, you will see the first name, last name, email ID, and contact number of the new subscriber.
Check the response in Pabbly Connect. Verify that the contact details match what was submitted. Ensure that the integration is functioning correctly.
This successful test confirms that the integration between ClickFunnels and MailChimp via Pabbly Connect is operational.
5. Adding MailChimp as an Action in Pabbly Connect
The final step is to set up MailChimp as the action application in Pabbly Connect. Select MailChimp and choose the action event ‘Add New Member with Custom Fields’.
You will need to connect your MailChimp account by entering the API key and data center. To find your API key, log in to your MailChimp account, navigate to ‘Account’ > ‘Extras’ > ‘API Keys’.
Copy the API key from MailChimp. Enter the data center from your MailChimp URL (e.g., US6). Map the necessary fields from ClickFunnels to MailChimp.
After mapping the fields, save the configuration and send a test request. If successful, the new subscriber will appear in your MailChimp audience list.
By following this tutorial, you have successfully integrated MailChimp with ClickFunnels using Pabbly Connect. This automation ensures that every new contact added in ClickFunnels is automatically subscribed to your MailChimp list, streamlining your subscriber management process. With Pabbly Connect, you can enhance your marketing efforts effortlessly.
