Learn how to integrate Kajabi with SMS marketing platforms like Twilio using Pabbly Connect in this detailed tutorial. Automate your SMS sending process effortlessly! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To integrate Kajabi with SMS marketing platforms, the first step is to access Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. You can start by visiting the Pabbly Connect website, where new users can sign up for a free account to explore its features.
Once logged in, navigate to the dashboard and click on the blue button labeled ‘Create Workflow’. Here, you need to name your workflow, such as ‘Connect Kajabi and Twilio’, and then click ‘Create’. This action sets up the framework for your automation process.
After setting up your workflow, the next step involves configuring the trigger event. In this case, select Kajabi as the first application. The trigger event will be set to ‘Form Submission’, meaning that whenever a form is submitted in Kajabi, it will trigger the automation. This is where Pabbly Connect plays a crucial role in facilitating this connection.
- Select ‘Kajabi’ as the application for the trigger.
- Choose ‘Form Submission’ as the trigger event.
Once you have copied the webhook URL, go back to your Kajabi dashboard. Under the marketing section, find the forms option and select your desired form. Click on the three dots in the upper right corner and choose the webhooks option to paste the copied URL. This action connects your form to Pabbly Connect.
3. Testing the Trigger for Successful Data Capture
With the trigger configured, it’s time to test the connection. Go back to your Pabbly Connect dashboard and click on the ‘Recapture Webhook Response’ button. This feature allows you to verify that the data from Kajabi is being captured correctly. Here, Pabbly Connect ensures that the automation is functioning as intended.
To perform the test, fill out the form in Kajabi with dummy details. For instance, you can input a name, email, and phone number. Once you submit the form, Pabbly Connect will capture the response, confirming that the integration is successful. You should see the captured data displayed in your Pabbly Connect dashboard.
4. Setting Up SMS Integration with Twilio
Now that the trigger is working, the next step is to set up the action event to send SMS via Twilio. Choose Twilio as the second application in your workflow. In this step, Pabbly Connect connects Kajabi with Twilio, allowing SMS messages to be sent automatically upon form submission.
- Select ‘Twilio’ as the action application.
- Choose ‘Send SMS’ as the action event.
- Connect your Twilio account by entering your Account SID and Auth Token.
After connecting Twilio, you will need to craft the SMS message. You can use the data captured from the Kajabi form submission to personalize the message. For instance, include the customer’s name and seminar details in the SMS body. This ensures that each recipient receives a tailored message, enhancing the customer experience through Pabbly Connect.
5. Finalizing and Testing the Integration
Once the SMS settings are configured, it’s time to finalize the setup and test the entire workflow. Ensure that you have mapped the recipient number correctly and that the SMS body contains all necessary information. This is where Pabbly Connect proves its effectiveness by automating the entire process.
After confirming all settings, click the button to send the SMS. You should receive a notification that the SMS has been sent successfully. This step validates that your integration between Kajabi and Twilio via Pabbly Connect is complete and functioning as expected.
Integrating Kajabi with SMS marketing platforms like Twilio through Pabbly Connect streamlines your communication process. By following these steps, you can automate SMS notifications based on form submissions, enhancing your marketing efforts effectively. Utilize Pabbly Connect to take your automation and SMS marketing to the next level!
