Learn how to integrate Instamojo with GetResponse using Pabbly Connect to automate customer contact creation on successful payments. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To integrate Instamojo with GetResponse, you first need to access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly.
Log in to your Pabbly Connect account and navigate to the dashboard. From here, you can start creating your integration workflow by selecting the applications you want to connect.
2. Setting Up Instamojo in Pabbly Connect
To begin, you will set up Instamojo as your trigger application in Pabbly Connect. Click on ‘Create Workflow’ and name it appropriately, such as ‘Instamojo to GetResponse Integration’.
- Select Instamojo as the Trigger Application.
- Choose the trigger event as ‘Payment Successful’.
- Authenticate your Instamojo account by providing the necessary API keys.
Once you have successfully authenticated, you can test the trigger to ensure that it captures the payment details. This step is crucial for the integration to function correctly.
3. Configuring GetResponse in Pabbly Connect
Next, you will configure GetResponse as the action application in Pabbly Connect. This step allows you to create a new contact in GetResponse whenever a payment is successful in Instamojo.
- Select GetResponse as the Action Application.
- Choose the action event as ‘Create Contact’.
- Authenticate your GetResponse account by entering your API key.
After authenticating, you will need to map the fields from the Instamojo trigger to the GetResponse action. This includes fields such as name, email, and phone number of the customer.
4. Testing the Integration
Once everything is set up, it’s time to test the integration using Pabbly Connect. Initiate a test payment in Instamojo to see if the customer details are sent to GetResponse correctly.
Check your GetResponse account to verify that the new contact has been created with the correct details. This step is essential to ensure that your integration works as intended and that customer information is accurately captured.
If the test is successful, you can activate the workflow in Pabbly Connect. This means that every time a payment is successful in Instamojo, a new contact will automatically be created in GetResponse.
5. Conclusion
Integrating Instamojo with GetResponse using Pabbly Connect allows you to automate the process of capturing customer details on successful payments. This integration enhances your marketing efforts by ensuring that every customer interaction is logged efficiently.
By following the steps outlined above, you can set up this integration quickly and effectively. Start using Pabbly Connect today to streamline your workflows and improve your business operations.
