Learn how to integrate Instagram and Discord using Pabbly Connect. This step-by-step guide will help you automate notifications for new Instagram posts in Discord. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating Instagram and Discord, you need to access Pabbly Connect. Simply search for ‘Pabbly Connect’ in your browser and navigate to the landing page.
Once on the landing page, you will have two options: ‘Sign In’ and ‘Sign Up for Free’. If you’re a new user, click on ‘Sign Up for Free’ to create your account. Existing users should click ‘Sign In’ to access their dashboard.
After signing into Pabbly Connect, you will see various applications. Click on ‘Access Now’ under Pabbly Connect to enter your dashboard. Here, you can start creating your automation workflow.
To create a new workflow, click on the ‘Create Workflow’ button. You will be prompted to name your workflow and select a folder. Name your workflow something like ‘Share Instagram Post to Discord’ and save it in the ‘Automations’ folder.
3. Set Up the Trigger for Instagram
In this section, you will set up the trigger for your workflow using Pabbly Connect. Select Instagram as your trigger application. This means that the automation will start when a new post is made on your Instagram account.
Choose the trigger event as ‘New Media Posted in My Account’. Click on ‘Connect’ to establish this connection. If you haven’t connected your Instagram account yet, you will need to add a new connection and grant permissions to Pabbly Connect.
- Select Instagram as the trigger application.
- Choose ‘New Media Posted in My Account’ as the trigger event.
- Connect your Instagram account and allow necessary permissions.
Once connected, click on ‘Save and Send Test Request’ to capture the details of the latest post. This confirms that your trigger setup is successful and ready to proceed to the action step.
4. Set Up the Action for Discord
The next step involves setting up the action using Pabbly Connect. Select Discord as your action application. This means that the automation will send a notification to your Discord channel when a new Instagram post is made.
Choose ‘Send Channel Message’ as the action event. Click on ‘Connect’ to link your Discord account. Make sure you have logged into your Discord account beforehand for a smooth connection.
- Select Discord as the action application.
- Choose ‘Send Channel Message’ as the action event.
- Connect your Discord account and specify the channel.
After connecting, you’ll need the webhook URL from your Discord channel. Go to your Discord server settings, select Integrations, and copy the webhook URL to paste it into the action setup in Pabbly Connect.
5. Finalize the Automation Workflow
To complete your automation, you will now customize the message that will be sent to Discord. Use Pabbly Connect to map the Instagram post link dynamically in the message.
Compose your notification message, such as: ‘Hey Discord fam, I just shared a new post on Instagram. Please check it out here: [Instagram Post Link]’. Make sure to replace the placeholder with the mapped link from the previous step.
Finally, click on ‘Save and Send Test Request’ to send a test message to your Discord channel. Check your Discord channel to confirm that the message has been received successfully. If everything looks good, your integration is complete!
Using Pabbly Connect, you can easily automate the process of sharing your Instagram posts to Discord. This integration helps keep your community updated with your latest content effortlessly.
