Learn how to integrate HubSpot and Sendinblue using Pabbly Connect to automate deal creation for new contacts. Follow this detailed tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To start the integration process between HubSpot and Sendinblue, you need to access Pabbly Connect. Visit the Pabbly Connect website and either sign in or create a new account if you don’t have one.
Once logged in, you will be directed to the Pabbly Connect dashboard. Click on the Access Now button to enter the integration interface. This is where you will set up the workflow to automate the creation of deals in HubSpot whenever a new contact is added in Sendinblue.
After accessing Pabbly Connect, click on the Create Workflow button located on the right side of the dashboard. Name your workflow appropriately, such as ‘Create HubSpot Deal for New Sendinblue Contacts’ and click on Create.
- Choose Sendinblue as the trigger application.
- Select the trigger event as New Contact Added in a List.
This webhook URL will be used to connect Sendinblue with Pabbly Connect, enabling the automation of the workflow.
3. Configuring Sendinblue to Work with Pabbly Connect
Next, log into your Sendinblue account and navigate to the Settings under the Contacts section. Here, find the Webhooks option and click on it.
- Click on Add New Webhook.
- Paste the webhook URL you copied from Pabbly Connect.
- Select the event to trigger the webhook when a new contact is added.
After adding the webhook, return to Pabbly Connect and wait for it to capture the response from Sendinblue, which will confirm the integration is working correctly.
4. Mapping Data from Sendinblue to HubSpot
Once the webhook is set up and you have created a new contact in Sendinblue, return to Pabbly Connect to set up the action for HubSpot. Choose HubSpot as your action application and select Create a Deal as the action event.
To connect HubSpot, click on Add New Connection and authorize Pabbly Connect to access your HubSpot account. Once connected, you will need to map the data from the previous steps to the fields required by HubSpot for creating a deal.
Map the deal name to the title of the contact. Input the deal amount and close date. Add any additional notes or descriptions relevant to the deal.
This mapping ensures that all necessary information from Sendinblue is accurately transferred to HubSpot, allowing for seamless deal creation.
After mapping the data, click on Save and Send Test Request in Pabbly Connect. This action will create a deal in HubSpot based on the information provided from the Sendinblue contact.
Check your HubSpot account to verify that the deal was created successfully with all the correct details. If everything appears as expected, your integration is complete!
By following these steps, you have successfully automated the process of creating HubSpot deals for new contacts added in Sendinblue using Pabbly Connect. This integration streamlines your workflow and ensures that no potential deals are missed.
In this tutorial, we explored how to use Pabbly Connect to integrate HubSpot and Sendinblue, automating the creation of deals for new contacts. This integration simplifies your workflow and enhances efficiency.
