Learn how to automate adding Housing.com leads to Airtable using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin integrating Housing.com leads into Airtable, you need to access Pabbly Connect. Start by opening your web browser and navigating to the Pabbly Connect landing page by typing ‘Pabbly.com/connect’. This is where you will initiate the automation process.
Once on the landing page, you will see options to either sign in or sign up. If you are a new user, click on the ‘Sign up for free’ button to create an account and receive 100 tasks free each month. Existing users can simply click ‘Sign in’ to access their dashboard. After signing in, select ‘Access Now’ under Pabbly Connect to proceed.
After accessing your Pabbly Connect dashboard, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, which will prompt you to choose between the new workflow builder and the classic one. Select the new workflow builder for a modern interface. using Pabbly Connect
  • Enter a name for your workflow.
  • Choose a folder to save your workflow.
  • Click on the ‘Create’ button to open the workflow window.
This workflow window is crucial as it allows you to set up triggers and actions. Click on the ‘Add Trigger’ button to start configuring the integration.
3. Setting Up the Trigger for Housing.com Leads
In the trigger application section, search for and select Housing.com. For the trigger event, choose ‘New Leads’ and click on ‘Connect’. This will generate a webhook URL, which you will need to configure in your Housing.com account. using Pabbly Connect
To implement this webhook URL, reach out to your Housing.com account manager or backend team, as the platform does not provide a user interface option for this. Once the webhook is added, leads will automatically flow into your specified campaign.
After the configuration, return to Pabbly Connect to capture the lead details, which include the requirement, phone number, last name, first name, email address, and area. This data will be used to create records in Airtable.
4. Adding Action Step to Create Records in Airtable
Now that the trigger is set, it’s time to add the action step in Pabbly Connect to create records in Airtable. Search for Airtable in the action application section and select it. For the action event, choose ‘Create Record’ and click on ‘Connect’. using Pabbly Connect
You will have the option to add a new connection or select an existing one. If you’re creating a new connection, click on ‘Connect with Airtable’. You will need to grant permission for Pabbly Connect to access your Airtable bases. Choose the specific base, in this case, ‘New Leads’, and click ‘Grant Access’.
Once the connection is established, you can map the lead details captured from Housing.com to the corresponding fields in Airtable. This mapping ensures that the data is dynamic and updates with each new lead received.
After mapping all necessary fields, click on ‘Save and Send Test Request’. This action will create a new record in your Airtable base with the lead details. You should see the newly created lead, including their name, email address, phone number, requirement, and area.
  • Ensure all lead details are correctly displayed in Airtable.
  • Confirm that future leads will be automatically added without manual intervention.
Once this setup is complete, you can rest assured that every new lead from Housing.com will be added directly to your Airtable base seamlessly through Pabbly Connect. This automation saves time and enhances your lead management process.
In this tutorial, we explored how to integrate Housing.com leads directly into Airtable using Pabbly Connect. By following the outlined steps, you can automate lead management and enhance efficiency in your business operations. Automate your workflows today with Pabbly Connect for a seamless experience.
