Learn how to create Mailmodo contacts on FlexiFunnels form submission using Pabbly Connect. Follow this detailed tutorial for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To create Mailmodo contacts on FlexiFunnels form submission, you need to access Pabbly Connect. Start by navigating to the Pabbly Connect landing page. If you are a new user, click on ‘Sign Up Free’ to create an account, which takes less than two minutes and provides 100 free tasks monthly.
Once you have an account, click on ‘Sign In’. After logging in, you will reach the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. You will be prompted to name your workflow, so enter ‘Create Mailmodo Contacts on FlexiFunnels Form Submission’ and select a folder for organization.
In this step, you will set up the trigger for your integration using Pabbly Connect. Select ‘FlexiFunnels’ as the trigger application and choose ‘New Form Submission’ as the trigger event. This event will initiate the workflow whenever a form is submitted in FlexiFunnels.
- Select ‘FlexiFunnels’ as the trigger application.
After copying the webhook URL, navigate to your FlexiFunnels account. Go to the project settings of the specific page you want to connect, and paste the webhook URL in the advanced settings under the ‘Webhook’ section. Name the webhook for easy identification and save your settings. This establishes a connection between FlexiFunnels and Pabbly Connect.
3. Testing the Webhook Connection
Once you have set up the webhook, it’s time to test the connection. Return to Pabbly Connect, where you will see a message indicating that it is waiting for a webhook response. Now, go back to your FlexiFunnels account and perform a test submission on the form you connected.
- Fill in the form with dummy data, including first name, last name, email, and phone number.
- Click on submit to send the test data.
- Check back in Pabbly Connect to see if the data was received.
After submitting the form, you should see the data reflected in Pabbly Connect, confirming that the trigger is functioning correctly. This step is crucial to ensure that your integration is set up properly before moving on to the action step.
4. Configuring the Action to Add Contacts in Mailmodo
Now that the trigger is set up, the next step is to configure the action in Pabbly Connect. Select ‘Mailmodo’ as the action application and choose the action event ‘Add Contact to List’. This action will automatically add a new contact to your Mailmodo account whenever a form is submitted in FlexiFunnels.
To connect Mailmodo with Pabbly Connect, you will need to enter your Mailmodo API key. First, go to your Mailmodo account, navigate to settings, and find the API keys section. Create a new API key, copy it, and return to Pabbly Connect to paste it in the required field.
Select ‘Add Contact to List’ as the action event. Enter the Mailmodo API key in the connection settings. Map the fields from the FlexiFunnels submission to the Mailmodo contact fields.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’. If everything is set up correctly, you will receive a success message indicating that the contact has been added to your Mailmodo list.
5. Conclusion: Automating Contacts with Pabbly Connect
In this tutorial, we successfully integrated FlexiFunnels with Mailmodo using Pabbly Connect. By setting up a trigger for new form submissions and an action to add contacts, we automated the process of creating Mailmodo contacts seamlessly.
With this integration, you can ensure that every new lead captured through FlexiFunnels is automatically added to your Mailmodo account, streamlining your marketing efforts. If you follow these steps accurately, you’ll be able to leverage the power of Pabbly Connect for efficient automation.
By utilizing Pabbly Connect, you can integrate various applications beyond just FlexiFunnels and Mailmodo, enhancing your overall productivity and efficiency.
