Learn how to integrate Facebook leads into Google Sheets for your solar energy business using Pabbly Connect. Follow this step-by-step tutorial for seamless automation. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To integrate Facebook leads into Google Sheets for your solar energy business, you first need to access Pabbly Connect. Start by visiting the Pabbly website and signing in or signing up for a free account if you don’t have one.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow specifically for adding Facebook leads to Google Sheets. Click on the ‘Create Workflow’ button to begin.
In this section, you will set up your workflow to connect Facebook leads with Google Sheets. After clicking ‘Create Workflow’, name it something descriptive, like ‘Add Facebook Leads to Google Sheets for Solar Energy Business’. Then, select a folder to save your workflow.
- Click on ‘Create’ to open the workflow setup.
- You will see two sections: Trigger and Action.
- Select ‘Facebook Lead Ads’ as your Trigger application.
Next, choose the trigger event as ‘New Lead Instant’. This will ensure that every time a new lead is generated, it will trigger the workflow. Proceed to connect your Facebook Lead Ads account with Pabbly Connect by clicking the ‘Connect’ button.
3. Connecting Facebook Leads to Pabbly Connect
After selecting the trigger event, you need to establish a connection between Facebook Lead Ads and Pabbly Connect. Click on ‘Add New Connection’ and authorize access to your Facebook account. Make sure to allow all required permissions.
Once connected, select your Facebook page that is associated with your solar energy business. Choose the lead generation form you want to use. It’s crucial to ensure your lead generation form is live for this to work effectively.
- Select the ‘Solar Rise’ page from your Facebook account.
- Choose the appropriate lead generation form.
After selecting the form, click on ‘Save and Send Test Request’ to ensure everything is set up correctly. You will need to create a sample submission to generate a test response.
4. Adding Leads to Google Sheets
Now that your trigger is set up, it’s time to configure the action to add the leads into Google Sheets. Select ‘Google Sheets’ as your action application and choose the action event ‘Add New Row’.
Connect your Google Sheets account with Pabbly Connect by clicking ‘Add New Connection’. Authorize access to your Google account, and then select the spreadsheet where you want the leads to be added.
Choose the spreadsheet named ‘Facebook Leads’. Map the columns: Full Name, Email, and Phone Number.
Mapping is essential as it ensures that the data from Facebook leads is correctly placed in the corresponding columns of your Google Sheets. Click on ‘Save and Send Test Request’ to verify that the integration works as intended.
5. Testing the Integration
After setting up your workflow, it’s important to test the entire integration to ensure that Facebook leads are being added to Google Sheets correctly. Go back to the lead generation form and submit a test lead.
Once submitted, check your Google Sheets to confirm that the new lead appears as a new row. This will validate that your connection between Facebook Lead Ads and Google Sheets is functioning properly through Pabbly Connect.
To further ensure everything is operational, repeat the submission process with different lead details. This will help you confirm that your integration is robust and reliable.
In this tutorial, we covered how to integrate Facebook leads into Google Sheets for your solar energy business using Pabbly Connect. By following these steps, you can automate the process of adding new leads, enhancing efficiency and lead management.
