Learn how to automate the enrollment of Zenler users from Facebook Lead Ads using Pabbly Connect. Step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start automating the enrollment process of Zenler users from Facebook Lead Ads, first, access Pabbly Connect. This platform allows seamless integration between various applications, including Facebook and Zenler. If you are a new user, you can sign up for free and receive 100 tasks every month.
Once you have signed in, navigate to your dashboard. From here, you will select Pabbly Connect by clicking on the ‘Access Now’ button. This action will direct you to the Pabbly Connect dashboard, where you can create your workflow.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button located in the top right corner. You will be prompted to name your workflow and choose a folder to save it in. For this integration, name the workflow ‘Enroll Zenler User for Facebook Lead Ads Lead’ and select the folder named ‘Facebook Lead Ads Automations’. using Pabbly Connect
  • Click on the ‘Create’ button to establish your workflow.
  • Understand the two key components: Trigger and Action.
  • Set up your trigger first, which captures the new leads from Facebook Lead Ads.
Your workflow is now ready, and you can begin configuring the trigger that will initiate the automation process.
3. Setting Up Trigger with Facebook Lead Ads
For the trigger application, select Pabbly Connect and then choose ‘Facebook Lead Ads’ as the trigger app. The event you want is ‘New Lead Instant’, which captures new leads as they come in. Click on the ‘Connect’ button to establish a connection between Facebook Lead Ads and Pabbly Connect.
Log into your Facebook account and authorize the connection. After authorization, you will need to select the Facebook page and the lead form associated with your ads. For example, choose the page named ‘Spark Success Coaching’ and the lead form titled ‘Course Registration Form’.
4. Testing the Connection and Capturing Leads
After setting up your trigger, it’s crucial to test the connection. To do this, generate a test lead using the Facebook Lead Ads Testing Tool. Ensure you select the same page and lead form you previously configured. Fill out the required details such as first name, last name, email, and phone number.
  • Click on the ‘Continue’ button to submit the test lead.
  • Return to Pabbly Connect to verify that the lead information has been captured successfully.
Once the test lead is captured, you can proceed to set up the action step which will enroll the captured lead into your Zenler account.
5. Enrolling User in Zenler
The next step is to enroll the captured lead as a user in your Zenler account. For this, select Zenler as your action application and choose the action event ‘Add New User’. Click ‘Connect’ to set up the connection between Zenler and Pabbly Connect.
Provide the required API key and school URL from your Zenler account. Once connected, map the fields from the captured lead to the respective fields in Zenler, including first name, last name, email, and phone number. After mapping the data, click on ‘Save and Send Test Request’ to add the user.
To finalize the process, check your Zenler account to confirm that the new user has been successfully enrolled. This completes the integration process between Facebook Lead Ads and Zenler using Pabbly Connect.
In this tutorial, you learned how to automate the enrollment of Zenler users from Facebook Lead Ads using Pabbly Connect. This integration saves time and enhances the onboarding experience for new students. By following these steps, you can efficiently manage your leads and streamline your course enrollment process.
