Learn how to seamlessly integrate Elementor Forms with Mattermost using Pabbly Connect. This step-by-step tutorial covers everything you need to know. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Access Pabbly Connect to Start Integration
To begin integrating Elementor Forms with Mattermost, first, you need to access Pabbly Connect. Sign up for a free account if you haven’t already, which allows you to create automation workflows without any coding skills.
Once you are signed in, navigate to the Pabbly Connect dashboard. Here, you will initiate the process by creating a new workflow specifically for sending leads from your Elementor Forms to Mattermost.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this tutorial, name it ‘Send Leads Data from Elementor Forms to Mattermost’. After naming, click on the ‘Create’ button to proceed.
Once your workflow is created, you will see options for setting up a trigger and an action. The trigger will be the new form submission from Elementor, and the action will be sending this data to Mattermost. This setup is essential as it outlines how Pabbly Connect will automate the process.
3. Set Up Trigger for Elementor Forms
Now, select ‘Elementor’ as the app for your trigger. Choose ‘New Form Submission’ as the trigger event. Upon selection, you will receive a webhook URL from Pabbly Connect, which is critical for receiving the form data. using Pabbly Connect
Copy this webhook URL and head over to your WordPress dashboard where your Elementor Forms are set up. Edit the form you want to connect and navigate to the ‘Actions After Submit’ section. Add a new action called ‘Webhook’ and paste the copied URL into the appropriate field. After updating the form, you will see that Pabbly Connect is ready to receive data from your Elementor Form submissions.
4. Test the Webhook Connection
With the webhook URL set up, it’s time to test the connection. Fill out your Elementor Form with sample data and submit it. This action will trigger the webhook, sending the form data to Pabbly Connect. You should see the submitted data appear in your workflow under the response received section.
Confirm that the data from your test submission is correctly captured. This step ensures that the integration is functioning as expected before moving on to connect with Mattermost.
5. Connect Mattermost in Pabbly Connect
Next, it’s time to set up the action in Pabbly Connect. Select ‘Mattermost’ as the application for the action step. Choose ‘Create a Post’ as the action event. You will need to connect your Mattermost account by providing the API token and the Mattermost URL.
To find your API token, go to your Mattermost profile settings under the security section. Create a new token and copy it into Pabbly Connect. Also, paste the Mattermost URL from your Mattermost dashboard. Once connected, select the appropriate team and channel where you want to send the lead data.
- Select the team in Mattermost to receive the leads.
- Map the lead data fields from Elementor to your message format.
- Test the connection to ensure messages are sent correctly.
Finally, send a test message to confirm that everything is set up correctly. You should see the lead information posted in your selected Mattermost channel, confirming that Pabbly Connect has successfully integrated the two applications.
Integrating Elementor Forms with Mattermost using Pabbly Connect streamlines the process of handling leads. By following these steps, you can automate lead submissions and ensure your team is promptly informed about new leads. This setup saves time and enhances productivity, allowing you to focus on your business growth.
