Learn how to integrate Dropbox and Telegram using Pabbly Connect to save new Telegram files effortlessly. Step-by-step tutorial for seamless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To save new Telegram files in Dropbox, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect homepage, where you can either sign in or create a new account. New users can sign up for free and get 300 tasks every month to explore the software.
Once logged in, you will see the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button located in the top right corner. This is where the integration process begins.
In this step, you will create a workflow specifically for saving new Telegram files. After clicking the ‘Create Workflow’ button, a dialog box will appear asking for a name. Enter a relevant name, such as ‘Save New Telegram Files’, and click on the ‘Create’ button. using Pabbly Connect
  • Name your workflow, e.g., ‘Save New Telegram Files’.
  • Proceed to set up the trigger.
After creating the workflow, you will be directed to the workflow window. Here, you will set up a trigger for the integration. Select ‘Telegram’ as your trigger application, and proceed to enter the necessary details to connect your Telegram bot.
3. Setting Up the Telegram Trigger
To set up your Telegram trigger, select ‘File Upload’ as the trigger event. You will need to provide a username for your Telegram bot. If the username is already taken, try another until you find an available one.
Once you have successfully created your bot, copy the token provided and paste it into the designated field in Pabbly Connect. After entering the token, click on the ‘Save’ button to complete the connection.
4. Configuring Dropbox Action in Pabbly Connect
After successfully setting up the Telegram trigger, it’s time to configure the Dropbox action. Select ‘Dropbox’ as your action application and choose ‘Upload File’ as the action event. Pabbly Connect will prompt you to connect your Dropbox account. using Pabbly Connect
  • Choose ‘Upload File’ as the action event.
  • Connect your Dropbox account to Pabbly Connect.
  • Map the fields to ensure the file uploads correctly.
Once connected, Pabbly Connect will ask for the file URL and other necessary details. Use the file URL received from the Telegram trigger to map it to the Dropbox upload action. After filling in all required fields, click ‘Save and Send Test Request’ to ensure everything is working correctly.
5. Testing the Integration
To test your integration, send a file to your Telegram group where the bot is added. After sending the file, go back to Pabbly Connect to check if the file was successfully uploaded to your Dropbox account. You should see a successful response indicating that the file has been uploaded.
If the test is successful, your integration is complete! You can now automatically save new Telegram files in Dropbox without any manual effort. This seamless integration is made possible entirely through Pabbly Connect.
This tutorial has guided you through the process of using Pabbly Connect to save new Telegram files in Dropbox. By following these steps, you can automate your file management efficiently. Enjoy the benefits of seamless integration with Pabbly Connect!
