Learn how to seamlessly integrate Cashfree Payments with Zoom to add registrants automatically using Pabbly Connect. Follow our step-by-step guide for successful automation. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Setting Up Pabbly Connect for Cashfree and Zoom Integration
To add registrants to a Zoom meeting automatically upon receiving successful Cashfree payments, you will first need to set up Pabbly Connect. Start by signing up for a free account on the Pabbly Connect website. This platform allows you to create automation workflows without any coding.
After signing in, navigate to your dashboard and click on the ‘Create Workflow’ button. Name your workflow, such as ‘Cashfree to Zoom Automation’, and click ‘Create’. This initiates the setup process for your automation workflow.
2. Configuring the Trigger Application: Cashfree Payments
In this section, you will configure Cashfree as the trigger application in Pabbly Connect. Select Cashfree from the list of applications and choose the trigger event as ‘Payment via Form’. This event will trigger the automation when a payment is successfully received.
- Select Cashfree as the trigger application.
- Choose ‘Payment via Form’ as the trigger event.
- Copy the provided Webhook URL for integration with Cashfree.
Next, go to your Cashfree dashboard, click on ‘Developers’, and select ‘Webhooks’. Here, paste the Webhook URL you copied from Pabbly Connect. Click on ‘Test and Add’ to confirm the connection. You should see a success message indicating that the connection is established.
3. Capturing Payment Data from Cashfree
Once you have set up the trigger, the next step is to capture the payment data. Perform a test payment using the form you created for meeting registration. This will allow you to ensure that the data is being captured correctly in Pabbly Connect.
- Fill in the test payment form with your details.
- Use test card details to simulate a successful payment.
- Confirm that the payment status is shown as ‘Paid’ in the response.
After completing the payment, return to Pabbly Connect to see if the payment data has been captured. You will see the details of the successful payment, which you will use to add the registrant to your Zoom meeting.
4. Adding the Registrant to Zoom Meeting
The final step in this integration process is to add the registrant to your Zoom meeting. In Pabbly Connect, select Zoom as the action application and choose ‘Add Meeting Registrant’ as the action event.
Connect to your Zoom account by clicking on ‘Connect’ and authorizing the integration. You will then need to specify the meeting name where the registrant should be added. Map the fields from the captured payment data to the corresponding registrant fields in Zoom, such as email address, first name, and last name.
By following the steps outlined in this tutorial, you can seamlessly integrate Cashfree Payments with Zoom using Pabbly Connect. This automation allows you to automatically add registrants to your Zoom meetings upon successful payments, streamlining your registration process. Enjoy the benefits of automation and enhance your workflow efficiency!
