Learn how to automate GoToTraining registration upon Cashfree payments using Pabbly Connect. Step-by-step guide for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin integrating Cashfree Payments with GoToTraining, access Pabbly Connect by visiting the URL Pabbly.com/connect. Here, you will find options to sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create an account. Existing users can log in directly. Once logged in, navigate to the dashboard of Pabbly Connect to start creating your automation workflow.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. A dialog box will prompt you to name your workflow. Name it ‘Create GoToTraining Registrant on Cashfree Payment’ for clarity.
Select the appropriate folder for your workflow and click on ‘Create’. This opens a new screen with two main sections: Trigger and Action. The Trigger is the event that starts the automation, while the Action is the event that follows.
3. Setting Up the Trigger with Cashfree
For this integration, select Cashfree as your trigger application. The specific event to choose is ‘Payment via Form’. This means that when a payment is received through a form on Cashfree, it will trigger the automation in Pabbly Connect.
After selecting the trigger event, you will be provided with a Webhook URL. Copy this URL, as it will be used in your Cashfree account to connect the two applications. Follow these steps to set up the webhook:
- Log into your Cashfree account.
- Navigate to the Developers section and select Webhooks.
- Click on ‘Add Webhook’ and paste the copied URL.
- Test and add the webhook to complete the setup.
Once the setup is complete, return to Pabbly Connect to confirm that the connection is successful by capturing a test response.
4. Setting Up the Action to Create a Registrant in GoToTraining
Now that the trigger is set up, it’s time to configure the action step. Select GoToTraining as the action application and choose the action event as ‘Create Registrant’. This is where information about the registrant will be sent once a payment is received.
Click on ‘Connect’ to establish a connection between Pabbly Connect and GoToTraining. If you are already logged into your GoToTraining account, the authorization will be successful. Enter the necessary details for the registrant, such as the training title, email, first name, and last name.
- Map the email and name fields from the previous response captured from Cashfree.
- Ensure that the data is dynamic to automate future registrations.
Once all necessary details are mapped, click on ‘Save and Send Test Request’ to finalize the setup. This will create a registrant in GoToTraining automatically.
After setting up both the trigger and action, it’s essential to test the integration to ensure it works correctly. Make a test payment using the Cashfree form to see if the registrant is created in GoToTraining.
Once the payment is processed, check your GoToTraining account under the registrations section. You should see the new registrant added successfully. This confirms that the integration via Pabbly Connect is functioning as intended.
With this setup, every time a payment is made through Cashfree, the registrant will be automatically added to your GoToTraining session, streamlining your registration process effortlessly.
Integrating Cashfree Payments with GoToTraining using Pabbly Connect allows for seamless automation of webinar registrations. This setup ensures that every payment triggers an automatic registration, enhancing efficiency and user experience.
