Learn how to integrate Campaign Monitor with Stripe using Pabbly Connect. This detailed guide covers all steps for adding new Stripe customers for new subscribers.
To start integrating Campaign Monitor with Stripe, you need to access Pabbly Connect. This platform allows you to create automated workflows between different applications. Begin by signing into your Pabbly Connect account or creating a new one if you don’t have it yet.
Once you’re logged in, navigate to the ‘Connect’ section. Here, you will find options to create a new workflow. Click on ‘Create Workflow’ and give your workflow a name that reflects its purpose, such as ‘Campaign Monitor to Stripe Integration’.
The next step involves setting up the trigger for your integration. In Pabbly Connect, select Campaign Monitor as the trigger application. You will need to choose the event that triggers the workflow, which in this case is ‘New Subscriber Added’.
- Select Campaign Monitor as the trigger application.
- Choose the event as ‘New Subscriber Added’.
- Connect your Campaign Monitor account by providing the necessary API key.
After connecting your account, you can test the trigger to ensure it’s functioning correctly. This step is crucial as it verifies that Pabbly Connect is receiving data from Campaign Monitor accurately.
3. Setting Up the Action to Create a Customer in Stripe
Now that the trigger is set, the next step is to define the action that occurs in Stripe. In Pabbly Connect, select Stripe as the action application. Choose the action event as ‘Create Customer’ to add new customers based on the subscribers from Campaign Monitor.
Fill in the required fields for customer creation, such as the subscriber’s email address and name. You can map these fields from the data received from Campaign Monitor. This mapping process is essential as it ensures that the correct data is sent to Stripe.
4. Testing and Activating Your Workflow
After setting up the action, it’s important to test your workflow. In Pabbly Connect, you can run a test to see if a new customer is created in Stripe when a new subscriber is added in Campaign Monitor. This test ensures that everything is configured correctly.
If the test is successful, you can proceed to activate your workflow. Click on the ‘Save’ button to enable the integration. This means that Pabbly Connect will now automatically create a new customer in Stripe whenever a new subscriber is added in Campaign Monitor.
5. Monitoring Your Integration Workflow
Once your integration is live, you can monitor its performance through Pabbly Connect. The platform provides logs and reports that show the status of each workflow execution. You can check if any errors occurred and troubleshoot them accordingly.
Additionally, you can make adjustments to your workflow settings at any time. If you need to change the trigger or action, simply navigate back to your workflow in Pabbly Connect and edit the necessary components.
This tutorial demonstrated how to integrate Campaign Monitor with Stripe using Pabbly Connect. By following these steps, you can automate the process of adding new Stripe customers for new subscribers added in Campaign Monitor, enhancing your marketing efficiency.
