Learn how to seamlessly integrate Brevo with Cashfree Payments using Pabbly Connect in this step-by-step tutorial. Automate your contact management effortlessly! Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Introduction to Pabbly Connect for Cashfree and Brevo Integration
Pabbly Connect is the ultimate automation platform that allows you to integrate various applications effortlessly. In this tutorial, we will use Pabbly Connect to automate the process of adding or updating contacts in Brevo whenever a payment is made through Cashfree. This integration ensures your customer database is always up-to-date, streamlining your marketing efforts.
To get started, navigate to the Pabbly Connect dashboard. If you are a new user, sign up for a free account to explore the features. Once logged in, you can access various applications offered by Pabbly, but today, we will focus specifically on Pabbly Connect for our integration.
2. Setting Up the Workflow in Pabbly Connect
To create the integration workflow, click on the ‘Create Workflow’ button in Pabbly Connect. You will be prompted to name your workflow; for this case, name it ‘Add or Update Brevo Contact on Cashfree Payment’ and select a folder to save it in.
- Select ‘Cashfree’ as your trigger application.
- Choose ‘Payment via Form’ as the trigger event.
This setup initiates the automation process. With Pabbly Connect, you can easily manage triggers and actions, ensuring a smooth workflow from Cashfree payments to Brevo contacts.
3. Connecting Cashfree to Pabbly Connect
After selecting Cashfree as the trigger application, you will receive a Webhook URL. This URL is essential for connecting your Cashfree account to Pabbly Connect. Copy this Webhook URL and log into your Cashfree account.
Navigate to the ‘Developer’ section, then go to ‘Payment Gateways’ and select ‘Webhooks’. Here, you will add the Webhook URL you copied earlier:
- Click on ‘Add Webhook Endpoint’.
- Paste the Webhook URL and click ‘Test and Add’.
Once you see a success message, your Cashfree account is now connected to Pabbly Connect. This integration will allow for real-time data transfer between applications.
4. Capturing the Test Response
To ensure that the integration works correctly, you need to capture the test response from Cashfree. Fill out the payment form with test details and complete a payment. Once the payment is successful, Pabbly Connect will capture the response automatically.
Check the workflow in Pabbly Connect to confirm that the response has been recorded. You should see all the details entered in the payment form, including the customer’s name and email. This confirms that the integration is functioning as expected.
5. Updating Brevo Contact with Pabbly Connect
Now that you have captured the response, the next step is to update or create a contact in Brevo. Select Brevo as the action application in Pabbly Connect and choose the action event as ‘Create or Update Contact’.
To connect Brevo, you will need to provide your domain and API key. Follow the instructions in Pabbly Connect to generate a new API key from your Brevo account. Once you have entered the required fields, map the details from the Cashfree response to the corresponding fields in Brevo:
Map the email, first name, and last name fields. Ensure that you set the update option to true.
After mapping all necessary fields, click on ‘Save and Send Test Request’. You should receive a confirmation that the contact has been successfully created or updated in Brevo.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding or updating contacts in Brevo whenever a payment is made through Cashfree. By following the steps outlined, you can ensure that your customer database remains current, enhancing your marketing and communication efforts. With Pabbly Connect, integrating applications has never been easier!
