Learn how to integrate BigCommerce with WhatConverts using Pabbly Connect. This detailed guide covers each step for seamless automation. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
Access Pabbly Connect for BigCommerce and WhatConverts Integration
To begin the integration process using Pabbly Connect, first open your web browser and navigate to Pabbly.com. Once on the site, hover over the ‘Products’ menu and select ‘Connect’ to access the Pabbly Connect dashboard.
If you do not have an account, you can create one for free in just a few minutes. Pabbly Connect offers a trial plan, allowing you to clone workflows directly from the platform. This is an excellent way to start your integration without any coding skills.
Create a Workflow in Pabbly Connect
After signing into Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will prompt you to name your workflow. For this integration, name it ‘BigCommerce to WhatConverts’ and then click on ‘Create’.
This will open a trigger window. In the ‘Choose App’ section, select ‘BigCommerce’ as the application from which we want to send data. For the trigger event, select ‘New Order Created’. This event will initiate the workflow whenever a new order is placed in BigCommerce.
Connect BigCommerce to Pabbly Connect
To connect BigCommerce to Pabbly Connect, click on ‘Connect with BigCommerce’. You will need to fill in three fields: Client ID, Access Token, and Store Hash Key. These credentials can be obtained from your BigCommerce account under the ‘Advanced Settings’ section.
- Navigate to BigCommerce and select ‘Advanced Settings’.
- Click on ‘API Accounts’ and then ‘Create API Account’.
- Fill in the necessary details and copy the Client ID, Access Token, and Store Hash Key.
Once you have filled in the credentials in Pabbly Connect, click on ‘Save’. This process will establish a connection between BigCommerce and Pabbly Connect.
Capture New Order Data from BigCommerce
To ensure that Pabbly Connect captures the new order data, click on the ‘Capture Webhook Response’ button. This will allow Pabbly Connect to start listening for any new orders placed in BigCommerce.
Next, go to your BigCommerce account and create a dummy order. Add a product to your cart, proceed to checkout, and complete the purchase. Once the order is placed, return to Pabbly Connect to verify that it has captured the order data successfully.
- Check the API response in Pabbly Connect for the new order data.
- Ensure that the customer information and order details are included.
If the data is captured correctly, you can proceed to the next step of extracting necessary information for creating a lead in WhatConverts.
Create a Lead in WhatConverts
To create a lead in WhatConverts, click on the plus button to add a new action step in Pabbly Connect. Select ‘WhatConverts’ as the application and choose the action event ‘Create Lead’.
Click on ‘Connect with WhatConverts’ and fill in the required fields: API Token and API Secret. These can be found in your WhatConverts account under the ‘Integrations’ section. After entering the credentials, click on ‘Save’.
Navigate to WhatConverts and select ‘Integrations’. Generate a new API key if necessary and copy the API Token and API Secret.
Next, map the customer data received from BigCommerce to the appropriate fields in WhatConverts. Finally, click on ‘Save’ and send a test request to ensure the lead is created successfully.
In this tutorial, we demonstrated how to integrate BigCommerce with WhatConverts using Pabbly Connect. This integration allows you to automate lead creation from new orders effortlessly. By following these steps, you can set up your workflow quickly and efficiently.
