Learn how to automate the creation of WordPress posts from Airtable records using Pabbly Connect. Follow this detailed tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To integrate Airtable with WordPress, first, you need to access Pabbly Connect. Go to Pabbly’s website and sign in or create a free account to get started. Signing up will give you free tasks every month, making it easy to automate workflows.
Once you are logged in, click on the ‘Create Workflow’ button located on the top right. Enter a name for your workflow, such as ‘Airtable to WordPress’, and proceed to set up the integration process.
In this step, you will configure the trigger application in Pabbly Connect. Select Airtable as your trigger app and choose the event ‘New Record’. This event triggers whenever a new record is added in Airtable.
Next, you will need to connect your Airtable account. Click on ‘Add New Connection’, and you will be prompted to enter your API key. You can find this key in your Airtable account under the account section. Copy the key and paste it into Pabbly Connect to establish the connection.
  • Select the base you want to work with, such as ‘WordPress Test’.
  • Create a new field named ‘Created’ with the field type set to ‘Created Time’.
  • Refresh the trigger to fetch the newly created field.
After setting up the trigger, you can create a new record in Airtable to test if the trigger captures the data correctly. This confirms that your Airtable is successfully integrated with Pabbly Connect.
3. Creating a WordPress Post through Pabbly Connect
Now that the trigger is set up, it’s time to configure the action step in Pabbly Connect. Choose WordPress as your action app and select the event ‘Create Post’. This action will create a post in WordPress whenever a new record is added to Airtable.
Connect your WordPress account by entering your username, password, and base URL. The base URL should be formatted correctly, excluding any paths like ‘/wp-admin’. Once connected, you can map the fields from Airtable to WordPress.
  • Map the post title from Airtable to the ‘Post Title’ field in WordPress.
  • Map the content body from Airtable to the ‘Content’ field in WordPress.
  • Select any tags or categories as needed.
Once all fields are mapped correctly, click on ‘Save and Send Test Request’ to create the post in WordPress. This step confirms that your integration is functioning properly through Pabbly Connect.
4. Verifying the Post Creation in WordPress
After executing the action step in Pabbly Connect, it’s essential to verify that the post has been created in WordPress. Navigate to your WordPress dashboard, click on ‘Posts’, and then ‘All Posts’ to see the list of posts.
Look for the title you used in Airtable. If the integration was successful, you should see the new post listed there with the correct content and metadata. This confirms that Pabbly Connect has successfully automated the process of creating a WordPress post from an Airtable record.
5. Conclusion
In this tutorial, we explored how to automate the creation of WordPress posts from Airtable records using Pabbly Connect. By following the steps outlined, you can seamlessly integrate these platforms and enhance your workflow efficiency. This integration not only saves time but also ensures that your content is published automatically as soon as it’s added to Airtable.
With Pabbly Connect, you can streamline your processes and focus on creating great content without worrying about manual updates. Start automating your WordPress posts today!
