Learn how to create ActiveCampaign contacts for new Razorpay payments using Pabbly Connect. This detailed tutorial covers all steps and UI elements for seamless integration.
To create ActiveCampaign contacts for new Razorpay payments, you need to access Pabbly Connect. Start by visiting the Pabbly website and signing in to your account. If you don’t have an account, you can sign up for free easily.
Once logged in, navigate to the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button to begin setting up your integration. You will name your workflow, for example, ‘Razorpay to ActiveCampaign.’ This workflow will automate the process of creating contacts in ActiveCampaign whenever a new payment is captured in Razorpay.
2. Setting Up Webhook in Razorpay
To connect Razorpay with Pabbly Connect, you need to set up a webhook. In the trigger application section, select Razorpay and choose the trigger event as ‘New Payment Captured.’ This will generate a webhook URL.
- Select Razorpay as the trigger application.
- Choose the trigger event: New Payment Captured.
- Copy the generated webhook URL.
Next, go to your Razorpay dashboard, navigate to Settings, and click on Webhooks. Create a new webhook by pasting the copied URL. Ensure that you select the event for test payment capture. This setup allows Pabbly Connect to receive payment data from Razorpay.
3. Capturing Payment Details in Pabbly Connect
After setting up the webhook, you can test the integration by making a payment. Go to the Razorpay payment page and enter your details. Once the payment is successful, Pabbly Connect will capture the payment details through the webhook.
- Make a payment using test card details.
- Pabbly Connect will show the captured payment details.
- Verify that the payment details include name, email, and phone number.
Once the payment is captured, you will see the details displayed in Pabbly Connect. This confirms that the integration is receiving data correctly from Razorpay, ready to be sent to ActiveCampaign.
4. Sending Data to ActiveCampaign
Now that Pabbly Connect has received the payment details, the next step is to send this data to ActiveCampaign. In the action application section, select ActiveCampaign and choose the action event ‘Create a Contact.’ This allows you to create a new contact in ActiveCampaign with the payment details.
Connect your ActiveCampaign account by providing the API URL and API key. To find these, go to your ActiveCampaign account settings. Make sure to copy only the necessary parts of the URL and paste them into Pabbly Connect. Once connected, map the fields like email, first name, last name, and phone number from Razorpay to ActiveCampaign.
5. Verifying Integration Success
Once you have mapped all the necessary fields in Pabbly Connect, click on ‘Save and Send Test Request.’ This action will create a new contact in ActiveCampaign using the payment details received from Razorpay. You should see a success message indicating that the contact has been created.
To verify, log into your ActiveCampaign account and check the contacts list. You should see the newly created contact with the details you provided during the payment process. This confirms that the integration works seamlessly, allowing you to automate your customer management effectively.
In this tutorial, we explored how to use Pabbly Connect to create ActiveCampaign contacts for new Razorpay payments. By following the detailed steps, you can automate the process of managing customer data efficiently. Integrating these applications enhances your workflow and saves valuable time.
