Learn how to integrate Active Campaign with Go High Level using Pabbly Connect for seamless automation. Follow this step-by-step guide to set up your workflow effortlessly.
To start integrating Active Campaign with Go High Level, first access Pabbly Connect. Open your browser and type in the URL for Pabbly Connect to reach the landing page.
On the landing page, you will see options to sign in or sign up for free. If you are a new user, click on ‘Sign up for free’ to create a new account. Existing users can simply sign in. Upon signing up, you will receive 100 free tasks to explore the platform.
Once logged into Pabbly Connect, navigate to the dashboard where you can create new workflows. Click on ‘Create Workflow’ in the top right corner.
- Name your workflow, for example, ‘Create Contacts in Go High Level from Active Campaign’.
- Select Active Campaign as your trigger application.
- Set the trigger event to ‘Contact Added’.
After setting these parameters, click on ‘Connect’ to establish a connection between Active Campaign and Pabbly Connect.
3. Connecting Active Campaign to Pabbly Connect
To connect Active Campaign with Pabbly Connect, you will need your API key and URL. In your Active Campaign account, go to the settings section, then select ‘Developer’.
- Copy the API key and paste it into Pabbly Connect.
- Copy the URL, ensuring to omit ‘https’ before pasting it into Pabbly Connect.
After entering these details, click ‘Save’. You will see that your Active Campaign account is now successfully connected to Pabbly Connect.
4. Creating a Contact in Go High Level
With Active Campaign connected, the next step is to create a contact in Go High Level. Select Go High Level as your action application in Pabbly Connect.
Choose ‘Create Contact’ as the action event. Click on ‘Connect’ and add a new connection to Go High Level. Ensure you are logged into your Go High Level account for easier connection.
Once connected, you will need to map the data from Active Campaign to Go High Level by filling in the required fields such as first name, last name, email, and phone number.
5. Testing the Integration
To ensure that everything is working correctly, create a new contact in Active Campaign. Fill in the details and click ‘Add’. This action will trigger the workflow in Pabbly Connect.
Return to Pabbly Connect to check if the response from Active Campaign has been received. If successful, you will see the new contact details populated in Pabbly Connect. After confirming the data, check your Go High Level account.
Refresh the contact section to see if the new contact has been created with the same details. This confirms that your integration between Active Campaign and Go High Level via Pabbly Connect is successful.
In this tutorial, we learned how to integrate Active Campaign with Go High Level using Pabbly Connect. By following these steps, you can automate the contact creation process seamlessly.
