Learn how to automate writing eco-friendly living articles using Pabbly Connect, Google Sheets, Google Docs, and more. Step-by-step tutorial included. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start automating your eco-friendly living articles, first access Pabbly Connect. Visit the Pabbly website and sign in to your account. If you are a new user, you can sign up for a free account, which allows you to use 100 tasks monthly.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can find all your workflows. Click on the ‘Create Workflow’ button to begin setting up your automation. This is where you will connect Google Sheets, OpenAI, and WordPress through Pabbly Connect.
2. Setting Up the Workflow in Pabbly Connect
In this section, you will create a new workflow for automating your article writing. Click on the ‘Create Workflow’ button and name it ‘Eco-Friendly Living Articles Using AI Agent’. Select the folder where you want to save this workflow.
- Choose Google Sheets as the trigger application.
- Select the trigger event as ‘New or Updated Spreadsheet Row’.
- Connect your Google Sheets account by following the prompts.
After setting the trigger, you will need to configure the Google Sheets connection. Copy the provided webhook URL from Pabbly Connect and paste it into your Google Sheets add-ons. This step is crucial as it allows data from Google Sheets to flow into Pabbly Connect.
3. Generating Content Using OpenAI
Next, you will set up OpenAI to generate content based on the data from Google Sheets. In the action step of your workflow, select OpenAI as the action application. Choose the action event as ‘Send Prompt’. using Pabbly Connect
Now, connect your OpenAI account by entering your API key. You can generate this key in your OpenAI account settings. Once connected, set up the prompt using the data received from Google Sheets. This is where you instruct OpenAI to create an article based on the title entered in your spreadsheet.
- Select the AI model you want to use, such as GPT-4.
- Map the title from Google Sheets to the prompt field.
- Set the prompt to generate a 500-word article.
After configuring the prompt, test this action to ensure OpenAI generates the content correctly. If successful, you will see the generated content in the response section.
4. Posting the Generated Article to WordPress
With the content generated, the next step is to post it to your WordPress site. In your Pabbly Connect workflow, add another action step and select WordPress as the application. Choose the action event ‘Create Post’. using Pabbly Connect
Connect your WordPress account by entering your login credentials and the base URL of your site. Once connected, set up the post details. Map the title from OpenAI’s response to the post title field and the generated content to the content field.
Select the post type as ‘Post’. Set the status to ‘Publish’. Skip optional fields like categories and tags if not needed.
After setting this up, test the action to ensure that the post is created on your WordPress site. If successful, you will see the new post listed under your posts in WordPress.
5. Finalizing the Automation Process
To finalize your automation, you need to ensure that the Google Sheets updates reflect in your workflow. Go back to your Google Sheets and add a new title in the designated column. This action should trigger the entire workflow.
Check your Pabbly Connect dashboard to confirm that the workflow executed successfully. You should see the generated article posted on your WordPress site. This seamless integration demonstrates how Pabbly Connect facilitates the connection between Google Sheets, OpenAI, and WordPress.
Now, you can automate the process of writing eco-friendly living articles efficiently. Whenever you add a new title in Google Sheets, the entire workflow will run, generating and posting content automatically.
In this tutorial, we explored how to automate the writing of eco-friendly living articles using Pabbly Connect, Google Sheets, OpenAI, and WordPress. This integration simplifies content creation, making it efficient and effective for environmentalists and bloggers alike.
