Learn how to automate writing business tips articles using Pabbly Connect. This detailed tutorial guides you through the integration with Google Sheets, AI, and WordPress.
To start automating the writing of business tips articles, you first need to access Pabbly Connect. This platform allows seamless integration between various applications like Google Sheets, AI agents, and WordPress.
Open your web browser and navigate to Pabbly.com/connect. Once there, you will see options to sign in or sign up. If you are a new user, select the ‘Sign Up for Free’ option to begin your journey with Pabbly Connect.
After signing into Pabbly Connect, you can create a new workflow by clicking on the ‘Create Workflow’ button. You will be prompted to name your workflow, so enter a suitable name like ‘How to Write Business Tips Articles Using an AI Agent’.
Next, select the appropriate folder where you want to save this workflow. If you don’t have a folder, you can create a new one. Once done, click on the ‘Create’ button to proceed. This is where you will set up the trigger and action for your automation.
  • Click on ‘Create Workflow’ after signing in.
  • Enter the workflow name and choose a folder.
  • Click ‘Create’ to set up your workflow.
Now that your workflow is created, you will see options to set up the trigger and action. This is a crucial step in utilizing Pabbly Connect effectively for your article writing process.
3. Setting Up Google Sheets as the Trigger
In this step, you will set Google Sheets as the trigger application in Pabbly Connect. Search for Google Sheets in the trigger application list and select it. For the trigger event, choose ‘New or Updated Spreadsheet Row’.
Once selected, you will see a Webhook URL. Copy this URL as it will be used in your Google Sheets. Open your Google Sheets and navigate to the ‘Extensions’ menu, then select ‘Get Add-ons’. Search for the ‘Pabbly Connect Webhooks’ add-on and install it.
  • Install the ‘Pabbly Connect Webhooks’ add-on in Google Sheets.
After installation, refresh your Google Sheets to see the new add-on. Go to the Pabbly Connect Webhooks option and set up the initial configuration by pasting the Webhook URL and selecting the trigger column. This setup will allow Pabbly Connect to detect new entries in your spreadsheet and trigger the automation.
4. Integrating AI Agent to Generate Articles
Now it’s time to integrate your AI agent for generating articles. In the action application section of Pabbly Connect, search for OpenAI and select it. Choose the action event as ‘Chat GPT Structured AI Output’. This will allow the AI agent to generate structured responses based on your input.
To connect your OpenAI account, you will need an API key. Visit the OpenAI API key page to create a new secret key. Copy this key and paste it into Pabbly Connect when prompted. After successfully connecting, you can set the AI model to use for generating articles.
Select OpenAI as the action application. Choose ‘Chat GPT Structured AI Output’ as the action event. Paste your OpenAI API key to connect.
Once connected, you can map the article title, target audience, and keywords from the Google Sheets input. This mapping allows Pabbly Connect to dynamically generate articles based on the details you provide in your spreadsheet.
5. Publishing Articles to WordPress
The final step is to publish the generated articles to your WordPress site. In Pabbly Connect, add another action step and select WordPress as the application. For the action event, choose ‘Create a Post’. You will need to connect your WordPress account by entering your username, password, and the base URL.
Once connected, you can map the AI-generated title and content to the respective fields in the WordPress post. After filling in the required fields, click on ‘Save and Send Test Request’. This will create a new post on your WordPress site using the article generated by your AI agent.
Select WordPress as the action application. Choose ‘Create a Post’ as the action event. Map the title and content from the AI agent to the WordPress fields.
After successfully publishing the post, you can check your WordPress dashboard to see the newly created article. This entire process showcases the power of automation using Pabbly Connect, allowing you to save time and streamline your content creation workflow.
In this tutorial, you learned how to automate writing business tips articles using Pabbly Connect. By integrating Google Sheets, an AI agent, and WordPress, you can efficiently generate and publish high-quality content. This automation not only saves time but also enhances productivity in your content creation process.
