Learn how to integrate Fitness Center New Leads with HubSpot and Campaign Monitor using Pabbly Connect in this detailed step-by-step tutorial. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Fitness Center New Leads with HubSpot and Campaign Monitor, first access Pabbly Connect. Simply open your browser and navigate to the Pabbly Connect website. You will have the option to either sign in or sign up for free if you are a new user.
If you are an existing user, click on the ‘Sign In’ button. After signing in, you will see a dashboard displaying all Pabbly applications. Click on ‘Access Now’ for Pabbly Connect to begin the integration process.
Once you are in Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow and choose a folder for it. Name your workflow something descriptive, such as ‘Integrating HubSpot with Campaign Monitor’.
- In the workflow window, you will set up the trigger and action.
- Remember, the trigger is what starts the workflow, and the action is what happens next.
After creating the workflow, you will see the options for setting up your trigger application. For this integration, select HubSpot as your trigger application. This means that whenever a new contact is created in HubSpot, it will trigger the workflow in Pabbly Connect.
3. Setting Up HubSpot as the Trigger Application
In this step, you will configure HubSpot as the trigger application in Pabbly Connect. Search for ‘HubSpot CRM’ and select it. For the trigger event, choose ‘New Contact Added’. This event will initiate the workflow when a new contact is created in HubSpot.
Next, click on ‘Connect’ to establish a connection with your HubSpot account. If you have not connected your HubSpot account previously, select ‘Add New Connection’. After selecting your account, grant the necessary permissions to allow Pabbly Connect to access your HubSpot data.
4. Defining Output Properties in Pabbly Connect
After successfully connecting HubSpot, you need to define the output properties you want to retrieve. In this case, you will select first name, last name, email, and phone number from HubSpot. using Pabbly Connect
- Select ‘First Name’ and ‘Last Name’ from the output properties.
- Choose ‘Email’ and ‘Phone Number’ as well.
- You can also add additional details like City and Country if needed.
Once you have selected all the desired output properties, click on ‘Save and Send Test Request’. This action will capture the latest contact details from HubSpot to verify that your trigger is working correctly.
5. Setting Up Action in Campaign Monitor
The final step involves setting up the action application, which in this case is Campaign Monitor. Choose ‘Campaign Monitor’ as your action application in Pabbly Connect. For the action event, select ‘Add Subscriber’.
Click on ‘Connect’ to link your Campaign Monitor account. If you haven’t connected it yet, follow the prompts to enter your API key and password. After successfully connecting, select the appropriate list from your Campaign Monitor account, such as ‘Fitness Center New Leads’.
Map the fields from the HubSpot response to the corresponding fields in Campaign Monitor. For example, map the email address and name fields. Once everything is set up, click on ‘Save and Send Test Request’ to create a new subscriber in Campaign Monitor. This completes the integration, allowing you to automatically add new contacts from HubSpot to your email marketing list using Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to integrate Fitness Center New Leads with HubSpot and Campaign Monitor. By following these steps, you can automate the process of adding new contacts to your email marketing campaigns, enhancing your engagement with potential clients.
