To start using Pabbly Connect, visit the Pabbly website. You will find options to sign in or create a free account. If you are a new user, click on “Sign Up Free” to get started with 100 free tasks each month.
Once signed in, you will see the dashboard. From here, you can access all Pabbly applications, including Pabbly Connect. Click on “Access Now” to enter the Pabbly Connect workspace where you can create your automation.
2. Creating a New Workflow Using Pabbly Connect
In Pabbly Connect, you can create workflows either from scratch or using AI features. For this tutorial, we will use the AI workflow builder. Click on “Create Using AI” to begin.
  • Select the trigger event, which in this case is when a form is submitted on Ple.
  • Next, choose the action you want to perform, such as adding the form data to Google Sheets.
After selecting the trigger and action, you will be prompted to set up the connection. This involves authenticating your accounts and mapping the necessary fields for data transfer. Once everything is set, click on “Create Workflow” to finalize your setup.
To set up your trigger, select the application from which you want to receive data—in this case, Ple. You will need to connect your Ple account to Pabbly Connect by clicking on “Connect with Ple” and authorizing access.
After successful authentication, select the specific form you want to use for this automation. For example, choose the “Registration Form” from the dropdown menu. This form will be the source of your data entries.
  • Make sure to test the connection to ensure it works correctly.
  • Once confirmed, proceed to the next steps in the workflow.
With the trigger set, you can now define the actions that will occur once the trigger is activated. This is where Pabbly Connect shines by allowing seamless data flow between applications.
4. Adding Action to Google Sheets via Pabbly Connect
After setting up your trigger, the next step is to add an action that will utilize the data received. Select Google Sheets as your action application and choose “Add a New Row” as the action event.
Connect your Google account to Pabbly Connect by clicking on “Sign in with Google”. Authorize Pabbly Connect to access your Google Sheets. Once connected, select the specific spreadsheet where you want to store the form submissions.
  • Choose the specific sheet within the spreadsheet to add data.
  • Map the fields from your Ple form to the columns in Google Sheets.
After mapping the fields, click on “Save and Send Test Request” to verify that the data is being sent correctly to Google Sheets. This step is crucial to ensure your automation works as intended.
5. Testing Your Integration with Pabbly Connect
Once you have configured your workflow, it’s time to test the integration. Make a test submission using your Ple form to see if the data appears in Google Sheets as expected. This step verifies the entire process.
After submitting the test data, check your Google Sheets to confirm that the new row has been added successfully. If everything looks good, your integration is ready to go live!
With Pabbly Connect, you can automate various tasks between Pabbly, Ple, and Google effortlessly. This integration allows you to manage your data efficiently without manual input, saving you time and effort.
In this tutorial, we explored how to integrate Pabbly, Ple, and Google using Pabbly Connect. By following the steps outlined, you can automate your workflows effectively and enhance productivity.
