Learn to automatically sync Telegram messages with WhatsApp using Pabbly Connect. Follow this detailed tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for Telegram and WhatsApp Integration
To start syncing Telegram messages with WhatsApp automatically, you need to access Pabbly Connect. This powerful automation tool allows you to connect multiple applications seamlessly. First, visit the Pabbly Connect website and log in or sign up for a free account.
Once logged in, you will find the dashboard. Click on the ‘Create Workflow’ button to initiate the integration process. You can name your workflow something descriptive, like ‘Sync Telegram Messages with WhatsApp’. This is the first step in setting up your automation.
In this section, you will create a workflow that triggers whenever a new message is received in your Telegram group. In Pabbly Connect, workflows consist of triggers and actions. The trigger will be the receipt of a message in Telegram, and the action will be sending that message to WhatsApp.
  • Click on ‘Create Workflow’ and name it.
  • Select ‘Telegram’ as the trigger application.
  • Choose ‘New Message’ as the trigger event.
After configuring the trigger, click ‘Connect’ to establish the connection between your Telegram account and Pabbly Connect. Follow the on-screen instructions to create a new bot using the BotFather in Telegram, which will help you connect your Telegram account to Pabbly Connect.
3. Connecting Your Telegram Bot to Pabbly Connect
To connect your Telegram bot, you need to create a new bot using the BotFather. Start by sending the command ‘/newbot’ in your Telegram app. You will then be prompted to name your bot and create a unique username. This bot will be used to receive messages from your Telegram group.
Once the bot is created, copy the token provided by BotFather. Return to Pabbly Connect and paste this token into the connection setup. This step is crucial as it allows Pabbly Connect to monitor messages from your Telegram group.
  • Add the bot to your Telegram group.
  • Make the bot an admin of the group to receive messages.
After adding the bot to your group, return to Pabbly Connect and test the connection. This ensures that every message sent in the group will be captured by Pabbly Connect.
4. Sending Telegram Messages to WhatsApp
With the Telegram bot connected, the next step is to set up the action that sends messages to WhatsApp. In Pabbly Connect, select ‘WhatsApp’ as the action application. Choose ‘Send Message’ as the action event. This allows you to configure how messages will be sent to your WhatsApp account.
In this section, you will need to connect your WhatsApp account to Pabbly Connect. You will be prompted to enter your WhatsApp account’s phone number and the template you wish to use for the messages. Ensure you have created an approved message template in your WhatsApp account to use.
Enter your phone number with the country code. Select the message template you created earlier.
After filling in these details, map the variables from the Telegram message to the WhatsApp message template. This ensures that the content of the Telegram message is included in the WhatsApp message.
5. Testing the Integration
After configuring both Telegram and WhatsApp in Pabbly Connect, it’s time to test the integration. Send a message in your Telegram group and observe the functionality. You should receive the same message on your WhatsApp account almost instantly.
This test confirms that the integration is working correctly. If everything is set up properly, every new message in your Telegram group will now be synced to WhatsApp automatically through Pabbly Connect.
Once you confirm that the integration works, you can close Pabbly Connect as it will run in the background, handling all future messages automatically without any manual intervention.
By following this tutorial, you can easily sync your Telegram messages with WhatsApp using Pabbly Connect. This automation saves time and ensures you never miss important messages from your Telegram groups. Start automating your tasks today with Pabbly Connect!
